Question about Bosch Microwave Ovens
Bosch oven and microwave combination appliance HBC 86Q650 B how do you replace the internal light bulb?
How do I replace the bulb on a Sanyo EMD9550 combination microwave?
Attached link is to a youtube video for a whirlpool microwave. It may give you enough information to replace the lamp on your microwave. Microwave Repair Replacing the Internal Light Bulb 40W Whirlpool Part...
Aug 16, 2014 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
The light in my microwave went out. how do i replace the light bulb?
Some have a plate on the interior of the oven that can be removed for easy bulb replacement but if yours does not you will have to remove the entire outer covering to access the bulb. If you have a combination microwave/Range vent you will have to remove the entire unit from the cabinet, then remove the outer cover, replace the bulb and re-install the combination unit.
Dec 13, 2011 | Microwave Ovens
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Microwave combination oven failureHME9750GB/03 FD8106 (/555350)
APPLIANCE HAS INTERNAL 8 AMP SAFETY FUSE IF THIS HAS BLOWN IT WILL NEED MAJOR REPAIRS AND POSSIBLY COSTLY THIS FUSE ONLY BLOWS IF FAULTS EXIST WITH HIGH VOLTAGE SIDE OF APPLIANCE SO NO NOVICE SHOULD ATTEMPT A REPAIR.
Jan 18, 2010 | Bosch HME9760 Microwave Oven
The internal light on my combination/microwave oven (HME9750) is no longer working. I can't see where the light fitting is, nor how to access it. Is this something that I can replace without major problems...
IF YOU TURN OFF POWER TO APPLIANCE AND WITHDRAW IT ABOUT 4 INCHES FROM HOUSING LOOK AT THE TOP YOU WILL SEE A PANEL WITH 2 SCEWS UNDO THIS TO SHOW BULB UNSCREW REPLACE AND REASSEMBLE.
Oct 19, 2009 | Bosch HME9760 Microwave Oven
Bosch HBC84K520B Combination Microwave Oven
If you google search bosch gourmet the second item down titled "bosch household appliances" you can download a manual from there
Jun 27, 2009 | Bosch HMB402 Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
