I need the drive that contains a region 3 media. where can i find this?
  • 32,281 Answers
DVD REGION FREE & BLUE-RAY REGION FREE
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
Posted on Jan 13, 2013
Y>x^2-4x+3
You need to draw the curve y= x^2-4x+ 3. It is a parabola. The equality (=) is verified by all points on the curve. The curve divides the whole plane in two regions. In one region y will be less than x^2-4x+3. In the other regions y will be larger than x^2-4x+3
The regions are the interior of the parabola and its exterior. To find out the region where your inequality is verified you proceed as follow.
  1. Look at the graph and choose the coordinates of one point. Select integer values (BTW the point (0,0) is usually a good candidate) and write y ? x^2-4x+3 where the ? stands for the inequality sign you will have to insert to make the relation correct.
  2. Take x=0, and y=0 and substitute in y ? x^2-4x+3
  3. 0 ? (0^2)-4*(0)+3.
  4. Clearly the ? stands for < because 0 <3.
  5. So at all the points in the region where (0,0) is located the condition y< x^2-4x+3 is TRUE.
In the other region y < x^2-4x+3, is FALSE and that second region (the one that does not contain the origin (0,0) is the one you need to find. It represents your solution set. Note that the origin (0,0) does not lie in the solution set region
wereup0ohrv3gaaaabjru5erkjggg==
Mar 03, 2014 | Casio FX82ES Scientific Calculator
DVD-RAW does not read DVD. It is unable to find a DVD. Is it DVD problem or player problem?
I think I've just answered this question :-
It won't be a driver problem, DVD drives are generic, it will be either the drive has a problem, the dvd has a problem or your media player has a problem
1) Drive issue - does it player other dvd's - if yes, your drive is ok, if now you have a drive problem, try using a CD lens cleaner or a blast of canned air to clean the lens.
2) Disk issue, if just one disk doesn't play, then its a disk issue or data issue. Assuming the disk is clean and not scratched. Does the Disk have the correct country coding for your region. If not then you have to change the region setting on your DVD player
RMB My computer - Manage - Device manager - Optical drive - Properties - Regional settings.
Bear in mind most DVD player will only allow about 5 changes.
3) Media player, your current media player may not have the correct codecs to decodes the video files on this disk. Go to filehippo.com download and install VLC media player. This will play about anything and its free.
Nov 27, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My driver is not working with DVD.it is unable to read DVD .
Region codes and windows vista??
Install Slysoft ANYDVD software, will bypass region locking on the fly.
It works very well.
Jan 03, 2010 | Computers & Internet
I CANT CHANGE THE REGION ON MY DVD, although I have 1 change left
you can flash the drive with region free firmware (best option if you know what youre doing)
you can reinstall os giving you extra tries.
or you can use a program called any dvd(free)which enable you to watch any region (safe)
flash is best if youre not sure or cant find software let me know and give your dvd details(firmware)
eg freecom dvdrw 523252
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Changing the DVD Region code
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
The first solution is free VideoLAN player: click here to download VideoLAN.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition Click Start Player button, and try to play your DVD
Finally Load another firmware for your DVD drive which disables the region code protection.
Jan 26, 2009 | Microsoft Windows XP Professional for PC
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
Should show region code
7 Select region
8 Press set-up to confirm and exit.
or
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
or
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
3 Press set-up
5 Press play
6 Input 251131
Nov 27, 2008 | Mintek MDP-1770 Portable DVD Player
Region Codes
In an emergency situation. heres your solution.
any Rom drive inserted into a PC, has a set amount of user changes. Some have 3 Some have 5 or So.
This was obviously, your final change.
Leave this one set as Region 2 ( UK PAL ) Purchase another Drive Now. Set it up on the same Or Different IDE Channel.
Set This Drive To Region 1 And Do-Not Change It.
You then have 1 region 1 Drive, And 1 Region 2 Drive.
This Way, you can also transfer from region 1 to region 2 encoding, On Each Individual Drive.
Only way, if your vendor Changes are at the End.
Hope this is a Succesful Fixya For You.
Mike @ compurepair.
Feb 25, 2008 | Pioneer DVR-1810A5PK 18x Internal Double...
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
