Question about Epson Stylus Pro 9600 InkJet Printer
Wont recognise ink cart
As i was removing light magenta, the little connector pins that actually read the chip on the ink cart have some how got ca\ught and pinged out now cant use the printer as it cant read chip. have i done some serious damage or can i some how trick it back into life.any help id be grateful for cheers
  • mrcshkns Jan 28, 2009
    I have also similiar problem.
    T5444 cartridge has been short of ink, and replaced with new one.
    But computer can not read the new cartridge.
    Perhaps the chip is wrong, but I can not solve it.
    How can help us with these proplem???
  • skipbj Sep 21, 2009
    My epson 2100 is sick the little pin things have come out of the one pinset where can I get one from please
I know how to fix this. This part is identical in many, many Epson models and I have lots this part. I call it the "pinset" and what it does is make contact to the chip on one side, and on a small board on the other to make the contact. The thing is, that you have to very carefully remove and insert this part and I have devised an excellent method of doing this during my several years of working with Epson printers, without taking the cartridge reciever apart as an authorized Epson tech would do. In fact, this happened recently to my Photo black slot and I fixed it in 10 minutes. It happens when someone tries to put a cartridge in with no chip on it. Putting it in is fine, but the spring loaded contacts get caught in the void where the chip is supposed to be and when you pull the cartridge out, it bends the hell out of the pinset. They are not repairable. I would not mind helping both of you... but I need something too. I have a 9600 PHOTO DYE model (T545* carts) and I either need a set of cartridges or a set of chips that I can reset. Empty, used, I don't care as long as the chip is intact and can be reset. You see, I have several bags of ink from a different model that I can change out inside the cartridges, but I don't have the right chips! Can you help me? I could send you as many pinsets as you need. I can definitely help you but I would rather arrange a meeting on the phone to walk you through it (both of you) since its a bit tricky without taking the printer apart.
Contact me and I'll privately give you my phone number.
Posted on Feb 14, 2009
  • gtmodel24 Feb 14, 2009
    OK.. So I just hopped on here and posted this answer. I will probably apply to be an expert here on Epson printers and I see after reading the agreement that I'm not supposed to solicit anyone or attempt to contact anyone outside the site. It's true I need the chips (or used cartridges) for a Photo dye 9600... but I didn't mean to imply that I wouldn't help you fix your problem if I didn't get them. So... here I'll tell you how to fix this.
    This solution will work on ANY Epson printer that accepts a chipped cartridge and only slightly vary according to how the cartridges go in. I've done this on several models of printer (2200, R1800, 4000 and 9600). This is the easiest method of changing this part without taking the whole darn printer apart.
    You'll have to get the pinsets from somewhere, and I'll just say that I have some. I know they are the same on a 4000, 4800, 4880, 7800, 7880, 9800, 9880. The ones from printers such as the R1800, R2400, R1400, etc, are slightly different but will work. I'm not quite sure which of these printers use a narrow one and which use a wide one - In any case, the pins are the same themselves. They just might have to be reinserted when you change that cartridge - the pins are the same but the plastic body is a bit narrower. See here that the damaged pinset is a bit wider than the new one... I only have pinsets from the 2200 but they work in a 9600. I just slide it back in before changing the cartridge. The pinset from a 2200 (I think the European model is a 2100 - same thing) worked just fine in a 4000.
    So, assuming that you have this part, you'll have to change it out. These pinsets snap in one way and you'll have to pretty much demolish the old one to get it out. If you have ever seen a multiwire connector under the hood of your car, this is how it's built. It has two little tabs on the sides that snap into the slot. See here. They are black and about 1/2" wide by about 3/4 of an inch long. Get a flashlight and look into the large slot where the cartridge goes in. You will see this little black piece that has the 7 gold, folded pins on it You will be looking at the end of it. Compare it to a cartridge slot that is not damaged to see how it sits in there. You see how the little tabs snap in? If you use a pinset from a smaller printer, they will never snap in. I have been debating putting a small drop of superglue at the end of mine to hold it in for when I change cartridges, but if it's damaged again it might make it hard to remove. Once you put one in a couple of times you'll see that it's not that big of a deal to slide it back in before putting in your new cartridge. BUT FINISH READING THIS FIRST because if you just try to slide it in there you will bend up and ruin the new one. There's a simple part that you will have to make out of some cardstock or heavy paper to put the new one in.
    The reason that you see this old one so badly damaged is that I marred it considerably while pulling it out with some needle nose pliers. You will basically be breaking the little tabs on the side. Get some long needlenose pliers that reach that far. DON"T ACCIDENTALLY GRAB OR DAMAGE THE BOARD THAT THE PINSET SITS UP AGAINST. Be very careful here only to grab this little pinset. Use ones that have some grip on the end and its a whole lot easier. After removing the old pinset, use a keyboard vacuum to get all the little pieces out. If part of the tab stays in there, the new pinset might not snap in correctly. If you do get the exact replacement and not the kind I have, it should snap back in correctly anyway.
    OK, so assuming you got the old one out. I am going to refer to the new pinset as having a "short" side and a "long" side. You'll see in this picture that the pins protruding from one side of the pinset are longer than on the other side. When putting the new one in, the LONG pins go up against the chip on the CARTRIDGE and the SHORT pins go up against the board in the PRINTER. You can see that the way the pins are bent into the pinset allow them to be springy and therefore push up against the board on one side and the chip on the other.
    Here is the dilemma - if you try to just push the pinset into the slot that accepts it, the way that the short pins are bent, they will actually push up against the edge of the small board in the printer and bend and this does not work. DON'T force the pinset into the slot as you will probably ruin it. I recommend getting a couple more than you need in case of this. What we will do is make a tool to "ramp" the pins into place. This will compress the pins as you slide the pinset in so that they don't bend and end up making correct contact on the internal board in the printer. This is simply cut out of a piece of cardstock, photo paper or something similar. Mine is made from a piece of glossy photo paper. You will notice that the end of it is exactly the width of the pins on the pinset. What you will be doing is sliding this long end into the slot that the pinset goes into. See here. If you take the new pinset between thumb and forefinger, and give it a pinch, you will see the pins squeeze in into the body of the pinset. This springiness is what allows the pins to stay put on the cartridge on one side and the board on the other. You can see the front edge of the board by looking straight in to the cartridge slot. Slide this paper tool INBETWEEN the small board and the slot that the pinset snaps onto. That way, when you push the new pinset in, the SHORT side pins will "ramp up" the cardstock/photo paper and therefore not bend as they slide into place on the board. I put a piece of tape on the large end of this so that when I get it in place, I secure it to the outside of the printer somewhere so it will hold itself. Just gently grip the pinset with needle nosed pliers and slide it in. You should not have to push very hard at all to get this to happen. Refer to an undamaged cartridge slot to see the orientation. When the pinset is flush up into it's recieving slot, simply hold it in place on the end facing you and pull the paper tool out. If you use something too thick it might get stuck! Business card thickness is about right - or 60# card stock. Regular 20# paper probably won't work, as it is not thick enough to depress the pins for the "ramp" effect.
    Now, if you used a pinset with a plastic body that isn't quite as wide as the one that was in there, (such as the difference between the 2 in my pictures) it will fall out when you remove the cartridge. Don't worry - putting a cartridge in a slot with no pinset won't damage anything - you will just get the "no ink cartridge" error. I have one now in my printer that falls out every time. Like I said, If you understand how it goes back in, it's not difficult to put back in when changing cartridges, which shouldn't be that often anyway. But, like I said before, NEVER put a cartridge that has no chip on it in an inkslot. It will snap in fine, then the pins will push out, and there is no way to then remove the cartridge without bending the hell out of the pinset.
    So, I hope this solves the problem for you. If you can't find the "wider" pinset for the 9600, I do have the narrow ones that will work and get you printing.
    Oh and please help me find some Photographic Dye chips or cartridges!
    (Oh man... now I see so many other issues on this site that I have excellent answers to....)
    BTW - When I was in 4th grade, my teacher gave us a simple assignment - write instructions on how to make a peanut butter and jelly sandwich. The next day, he brought in a couple loaves of bread, peanut butter and jelly. He then began reading our papers aloud, and following our instructions, one by one, EXACTLY and LITERALLY. The student whose instructions actually yielded a sandwhich got to eat that sandwhich in class. If a student said "Get a piece of bread and put some peanut butter on it"... that's just what he did - tear off a small piece of bread and set the jar of peanut butter on it. Some of them made quite a mess.
    My paper went like this... "Take one slice of bread and set it on your plate. Take the lid off of the peanut butter. Get a butter knife........". Needless to say I was the only student eating a sandwich that day. I just might love this site....
    Hope I helped.
Ink light will not out and cartiage have ink
Epson printers don't actually measure the amount of ink in the cart, but instead estimate the ink use by counting the number of drops used for printing and cleaning.
If the head has been clogged, then less ink gets used, and when the printer thinks the cart is empty there will be ink left in it.
You can get a chip resetter that can let you use the little bit of ink that's still in the cart.
Jan 11, 2015 | Epson Stylus CX4450 All-In-One InkJet...
1050c DESIGNJET REPLACE MAGENTA ISSUE
one of the first signs of a faulty power supply is a washed out display,
also you may hear a slight buzzing noise,
you may need to replace the ISS Pwb ( part of the tubes ) not order able separately,
it has been known that the connector block ( for ink Cart) does fail, I would try swapping it with another colours and see if the fault follws the connector block,
it may just be a bad chip on the ink cart.
Jun 07, 2013 | HP DesignJet 1050c InkJet Printer
Epson 2100 will not recognise new cartridges
Change ink tank using "How to..." at Epson status monitor. Check contactor that connected to ink tank chip at carriage. Other possibility is CSIC board (behind the contactor)
Jan 21, 2013 | Epson Stylus Photo 2100 InkJet Printer
Canon pro9000 mrk2 printer wont recognise yellow cart cli8 but if I lift out the cyan cart it will recognise the yellow until i fully seat the cyan back in the holder again
you do get this with a lot of canon printers its nor-manly the black, make shore you have the prober canon cart because some of the copy,s don't match the pin,s on the printer also clean the pin,s on the printer, that the cart fit,s back to with a cue tip but be care full not to hard as this my damage the pin,s which my be the cause. I would swap any way to a chip epson the ink,s cheaper
Nov 01, 2011 | Canon PIXMA Pro9000 Printer
On my HP Business Inkjet 1200 the black/magenta/yellow lights are flashing but not the cyan. Neither the printhead or ink cartridge light is lit. With 3 out of 4 lights lit what is the printer complaining...
You may be using non original ink catridges, the printer chip will not recognise so flashes as if needs replacing.if refills are original printer chip may need to be reset.
Feb 03, 2018 | HP Business Inkjet 1200dtn Printer
Refilled cartridge not recognised
dont you hate that when that happend. this is why i do not use refilled carts. The issue here is the ink system has failed because of the refilled cart. the chip that reads the cartridge (printhead) is bad and needs to be replaced. I got a link on a tip for you about refilled stuff I hope you do take it to heart.
http://www.fixya.com/support/r4622115-refill_print_cartridges_cost_money
Read the artical in there you be so glad you did. Refilled inks ruin printheads!!! and this is what happend to your printer. please read and please do rate the tip and leave feedback for this free help today.
Apr 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink cartridge error
Get a new magenta cart, but make sure you buy a genuine one, not a compatible. The chip on the cart in question may be faulty (approx 30% of compatibles can be faulty).
If the error does not go when a genuine cart is installed you may have a faulty main board or carriage.
Aug 26, 2008 | Epson Stylus Photo R320 InkJet Printer
Ink carts not recognised
OK, i know this one ;-)
1 take out the cartridge thats not recognised ( 1 or all dont matter)
2 do a ink change with no ink in
3 put ink cartridge(s) back in.... wiggle the cartridge(s) to seat the "chip" right
4 do a ink change again, if not just follow the steps again.
I had to do this 5 times the other day before it picked it up.
It does work
Jan 31, 2008 | Epson Stylus Photo R300 InkJet Printer
Model mfc-240c
did you replace with brother carts, are you sure machine is refering to mag and yellew being mt, not the other ones, power off, remove all carts, power on , reinsert carts one at a time answer machine when prompted. these cartridges are deemed empty even when they look like they have a little ink left. Try putting in 4 new brother inks
Nov 09, 2007 | Brother Multi-Function Center MFC-240C...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus Pro 9600 InkJet Printer Logo
293 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
