Question about Singer Sewing Machines
Singer curvy 8780 will not pick up the thread from the bobbin
I can not get the machine to pick the thread up from the bobbin and pull it through from the top
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
SOURCE: Singer 301a Bobbin troubles
I just had this problem, too - if you have the manual, check out page 15. If you have removed the throat plate, you need to make sure that the position finger on the bobbin case base enters a notch on the underside of the throat plate. Fixed my problem right away.
Posted on Mar 12, 2010
Testimonial: "You are absolutely spot on! THANK YOU!"
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
May 25, 2016 | Singer Sewing Machines
Brand new sewing machine wont stitch. Any ideas?!?!
I'm sure you've done this, but I'll just throw this out there. Did you pull the bobbin thread through the groove that slants on the left side of the needle plate starting from the upper left corner of the bobbin cover?
Feb 24, 2015 | Singer 8763 Curvy
How do i make my singer curvy 8780 stop sewing after i have finished sewing my fabric
Sounds like your brushes in your motor are worn. Either that or your foot peddle is sticking.
Feb 23, 2015 | Singer Curvy 8770 Electronic Sewing...
Sew for three seconds and it stops and beeps four times. I have changed my needle and made sure it's in correctly, i cleaned out the area under plate (only one month old), checked thread and thickness of...
Some sewing machines are extremely finicky about the direction the thread feeds from the bobbin. I had one machine that didn't care which way the bobbin fed and another that would stop after 2-3 stitches and protest. You could try flipping the bobbin and see if that helps.
Feb 03, 2018 | Singer Curvy 8770 Electronic Sewing...
Singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
Mar 31, 2012 | Singer Curvy 8770 Electronic Sewing...
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
I have Singer Curvy 8763. It seems that the foot control stopped to work. The machine does not sew, its impossible to wind the bobbin. It is possible however to sew backwards with the help of reverse...
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Nov 04, 2010 | Singer 8763 Curvy
My singer curvy is not pulling the thread from the bobbin when i lower the needle
Providing you have a new needle in the correct way round if it does not pick up the tread you will need to take it in to get retimed.
Nov 05, 2009 | Singer Sewing Machines
Sewing Machines Logo
124 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
