Question about Samsung SC-D353 Mini DV Digital Camcorder
Playback issues Recently, my camcorder has been suffering playback issues. When I play back a recording, the visual and sound are very choppy. It's the same way playing on a computer, too. What's even more confusing is that it's not always bad. Sometimes it works perfectly fine. Right now I think I just need to get it repaired.
  • Peter Thompson
    Peter Thompson Aug 11, 2007
    I had just thought of doing that [using a cleaning tape]. It worked, my camcorder works again. Some of my tapes seemed to be damaged by the dirty head, but otherwise it seems to be working.
  • 169 Answers
Try to forward a blank tape for cleaning until the head has being clean...repeat the procedure 5 times...if nothing happen may be the video head is weak already.....or need to align the camera
Posted on Aug 09, 2007
SOURCE:
Choppy recording
This could be to do with the format your using to playback.
Hope this helps!
Feb 05, 2010 | Cakewalk Sonar 5 Producer Edition Full...
No sound when playback or after finalized
Perhaps the microphone was muted while you were making the original recording? Have you tried playing back a new recording with the microphone active?
May 19, 2008 | Canon DC10 DVD Camcorder
Playback of video is choppy
Clean the Head of your Camcorder
Apr 26, 2009 | Video Cameras
E-System laptop with slow dvd playback
This can be a bit of a tricky one to figure out. My initial response would be that you have another program or process that is causing your computer to play 'choppy' video. When you have a newer computer that was recently working just fine and now all of the sudden the video is choppy, it is usually due to another process using CPU cycles that are so important to video playback.
Start playing a DVD, but don't go to full-screen mode. Open the Task Manager. Right-Click on the task bar and select Task Manager. Click on the 'Processes' tab. There is a column labeled CPU, click on the heading 'CPU' twice. This will order the processes in order from highest CPU usage to lowest. The top two processes will most likely be your DVD player and the process that is causing your choppy playback.If the offending process isn't essential (i.e. anti-virus), then click on said process and then click the "End Process" button.
Hope this helps.
Mar 09, 2009 | Computers & Internet
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
8mm Samsung camcorder: choppy playback
This seems like a tape playback problem. Can you look at the output of the tape in the camera directly into a monitor? And checking the tapes on another machine would also be good.
The fast movement breakup can be something in the playback circuitry of the camera. It may not show up in the viewfinder. Also yo umay try repacking the tape. Fast forward it to the end and rewind it all the way.
Oct 03, 2008 | Video Cameras
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Oct 05, 2007 | Sony Handycam DCR-TRV260 Digital Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
177 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
