Question about Reebok treadmill i-run s
I have power to the rbk i runner treadmill, but the treadmill/belt wont go around. any ideas
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: cannot open the running stand on rbk treadmill Iwalk Irun
see the video attached and proceed according. or see your instr. manual how to fold or unfold the treadmill. if you do not have the instr. manual go to www.fitness.manualsonline.com
and download free
Posted on Nov 30, 2012
Why wont it run?
Is the motor running? If not, is it receiving power? Is the belt slipping? If motor has brushes, they might need replacement.
Nov 18, 2015 | Nordic Track APEX 6100XI TREADMILL Console
Cannot open the running stand on rbk treadmill Iwalk Irun
and download free
Nov 13, 2012 | Reebok 8100 ES Treadmill Save Big!
I've got a Roger Black treadmill and on the screen it says manual and the belt wont go round when its plugged in any ideas why?
1) adjust the Reed Switch , see the diagram clean it, tight the wires connector very well.
2) tight the ribbon cables from keypads, tight the connector from display board vs lower board, clean it.
3) LUBE the deck belt, maybe you have a worn deck by lack of mainenance.
40 LUBE the rollers bearing too
5) measure the input voltage motor, if there are the motor need repair.
6) measure the output voltage board, for input voltage board, if there are NOT the board is faulty.
see the diagram
God bless you
Jul 23, 2012 | Exercise & Fitness
We had the lift frame crack on our Nordic Track A2550 after very limited use (but 1mo. after warranty). We replaced it in February and after 500 additional miles, the lift frame has cracked again. I...
General Construction
  • The most basic breakdown of a treadmill: a continuously moving belt powered by a motor over a deck that is mounted on a sturdy metal frame. The variables are the size of the belt, the power of the motor, the thickness and composition of the platform as well as the range of options that increase both function and cost of the treadmill. Making the right choices on all these permutations will add to the enjoyment and benefits of using your treadmill.
Frame Composition
  • Frames are generally made from aluminum or steel. Even if there's no difference in the tensile strength in the frames, steel is better because it will produce a heavier treadmill. That increases the machine's stability and lessens the vibrations generated by your exercise, especially running. Frames can be either bolted or welded together. Welded frames are stronger, and there is no risk of a bolt working loose during long periods of operating the treadmill.
Motor Size
  • Most treadmills have two electric motors. One raises and lowers the deck, allowing you to get a versatile workout. The more important motor is the one that moves the exercise belt under your feet. The drive motor turns a flywheel that is connected by a belt---similar to the belts for the engine of your car---to the front roller. The front roller pushes the exercise belt to the back of the treadmill where a free-moving rear roller serves as the exercise belt's turnaround point. Check for the continuous horsepower (CHP) and revolution per minute (RPM) rating on the motor. In fact, lift the motor cover and look for the ratings stamped directly on the motor. A motor that needs high RPMs (more than 5,000) to generate enough torque to drive the exercise belt is a candidate for overheating and is unlikely to last long. If your plan is only to walk---not run---on your treadmill, a 1.5-horsepower motor with less than 5,000 RPMs will suffice. But if you weigh more than 200 lbs. or you plan to run on your treadmill, you will need at least a 2-horsepower motor with an RPM rating of 4,000 or, preferably, less. Choosing one with 2.5 horsepower or more will be even better if you plan to run for long workouts. When in doubt, go up in horsepower. The motor not only moves the belt but it must overcome the resistance you provide with each stride. Smaller motors with high RPM ratings will allow the belt to hesitate slightly. In addition, you likely will be moving more slowly than the speed displayed on the treadmill's console if you are trying to run. Larger motors might be noisier, so look for a motor housing that absorbs some of the machine noise when the treadmill is in operation.
Belt Size
  • Your workout plans also will dictate what size belt and rollers you need. The treadmill's exercise belt will be made of a thin, multiply polyester/fabric mix with a PVC top coat, which produces the best combination for reducing friction and the heat it generates. This will extend the life of the belt and prevent slipping while you're in motion. Although the surface will be smooth against the deck, the PVC coating will be waffled underneath your feet for better traction. Even if you have short legs and you only plan to walk on the treadmill, you should get a belt at least 18 inches wide and 48 inches long. If you plan to run, a 20-inch belt width is better and 22 inches is best, and you shouldn't choose anything less than 54 inches in length. Longer---up to 60 inches---is better, especially for tall runners. The treadmill will run more smoothly with bigger rollers because the rollers will have more grip surface for the belt as it is propelled over the deck. If you plan to run on your treadmill, rollers with 2-inch diameter are the minimum. Some high-end treadmills come with 3.5-inch rollers. Larger rollers also result in less stress on the bearings; a 3.5-inch roller will need to rotate roughly 60 percent less than a 2-inch roller to cover the same distance.
Platform Surface
  • Treadmill decks are made of wood or, more specifically, composite wood substitutes, either particle board or medium density fiberboard (MDF). For runners, an MDF deck at least 1-inch thick is the minimum. A 3/4-inch surface might be OK for walking, but it will be too bouncy for running and will crack more easily. The deck surface will have a laminate coating---preferably on both sides---to allow the exercise belt to slide smoothly. Treadmills commonly have rubber grommets built into the frame to provide cushioning as you exercise. Some treadmills have shock absorption only in the front (landing area) so that you have a firmer push-off for your next stride. With the built-in shock absorption and the smooth surface, a workout on a treadmill is likely to be less stressful on your joints than running outdoors, unless you have access to a perfectly level wood-chip path.
Speed and Incline
  • Most treadmills now come equipped with easy-to-reach controls that allow you to change the belt speed and the incline of the deck while the belt is in motion. The lift motor generally uses a hydraulic lift to raise and lower the treadmill on its front legs. The elevation motor should have a thrust value of at least 400---more for runners---so the deck can be shoved up without any hesitation during exercise. Some treadmills use gears for elevation. That's neither as smooth nor as reliable as hydraulic lifts. The speed of the belt is controlled from the console of the treadmill. As you raise your speed by 1/10 mile per hour, the motor subtly increases the power it is generating to the rollers, much as a hair dryer does less subtly as you click from medium to high. For runners, look for a treadmill that provides a speed of at least 12 miles per hour and allows an elevation of at least 10 percent. That will give you the opportunity to include some speed work and hill training in your workouts.
More Features
  • Some treadmills come equipped with iPod ports, built-in TVs, drink holders, cooling fans, computer-generated workouts and heart-rate monitors. The computer workouts will build in elevation-change programs, and you can punch in the starting speed of your workout and change it manually. Treadmills also allow you to create programs in which you can choose both the speed and elevation changes. Heart-rate monitors calculate your heart beats per minute and can be operated continuously using chest or arm bands or intermittently using a finger clip or by gripping a sensor on the front rail with one hand. But none of these features outweighs the importance of choosing the right belt and motor for your workout.
Safety
  • Make sure the treadmill has a safety release---usually a magnetic key---so you can stop the exercise belt dead in the event of an injury or other emergency. The treadmill is wired so that the key must be in place on or near the console to complete the electronic circuit and allow the machine to operate. Yet the key can easily be yanked free, immediately stopping the drive motor and putting the brakes on the exercise belt.
Sep 21, 2011 | Nordic Track NordicTrack Treadmill, A2550
When I step on the treadmill, the runner stops and
Unplug unit then remove motor shroud the walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting..
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step If your treadmill is equipped with this bolt (very few are) the repair will only require one person.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller.
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Proform 575 Crosstrainer Treadmill
I have problem with my Proform 575. The motor rotates but the runner does not turn. There is a squeaky noise. Solution please.
It sounds like the belt is slack there should be an adjustment at the rear of the belt at either side of the treadmill usually a hex stud or allen key, if that doesn't help check the drive belt that comes directly from the motor which could also be slack or damaged.
Oct 18, 2009 | Proform 575 Crosstrainer Treadmill
V-fit treadmill belt wont turn
call the threadmill cops. they will come and beat up that error
Jun 24, 2009 | Exercise & Fitness
Hoggan Sprint Runner ltreadmill very noisy
I am the marketing director for HOGGAN Health. Check out the youtube.com video below, it will show you how to re-track the runner. If that doesn't help, call us: 800-678-7888 or visit HOGGAN Health Runner Treadmill for more info.
Jun 17, 2009 | Sportime Hoggan Sprint Runner Treadmill
Reebok treadmill i-run s Logo
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
