Broken electric 3-hole punch
We have a Swignline Model 535 electric 3-hole punch. One of the punches is stuck and it won't go back into its normal place (it is currently blocking the place where you insert paper). The reverse switch does nothing. If I hit the punching button, the stuck punch will move a little bit forward, but then won't go back any farther than where it is now. I have tried brute force methods (trying to force it back in) and now I am trying to disassemble it so I can see what's inside. But I can't get it open. In any case, we really need to get it fixed...
Thanks!
    Problem Solver:
  • 7 Answers
There are two phillips screws in the bottom. Once they are removed, the top and bottom of the case are held together with clips molded into the case. Take a wide flat screwdriver and place it in the seam and gently pry it apart. Might want to start on the back in case you ****** up the plastic.
Posted on Oct 25, 2009
Looking for a replacement cord for a sparco 96003 hole punch
Use any cord from something your throwing away that has a ground in the wire making it a 3 wire cord. White is common, black is power, and green is ground.
Nov 15, 2014 | Sparco High Volume Electric Three-Hole...
How to load 3 hole punch paper in a copier
Like normal. Those three holes should not affect the print at all as all of the rollers are flat. I would not not stick it in a dot matrix printer though.
Jun 05, 2014 | Computers & Internet
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
C11-32
The issue is with the punch unit. It may have a bad connection. It may also be something stuck in the paper detect sensor or the sensor is broken. All possibilities are with the punch kit.
Feb 18, 2014 | Konica Minolta bizhub Office Equipment &...
Cannot get the arm all the way up
this can be caused by excess paper stuck in the punch area. clean out all the excess paper, making sure to pay attention to the punch area. gently try to move the handle, it may take several tries to get the handle to move freely, make sure you clean out all excess paper before you use again.
Sep 23, 2013 | Swingline Swi-74650 Three-hole Punch - 3...
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Swingline Model 525 electric 3 hole punch
It has a safety switch. This switch turns machine on when it detects paper and off if it doesn't. Something wrong with sensor. Broken, paper stuck under it, out of position. Will have to open it up and check the sensor. ***Always remember to unplug any equipment before working on it***
Apr 18, 2010 | Office Equipment & Supplies
Broken chisel
The rubber end cap should just pry of the toll holder. Behind this ther is normally a snap ring or ciclip. Remove that and the chuck parts should all come off. Remember which order they were in. There is normall end cap, clip/ring, thick washer, dished washer and ball. Once all these parts are removes you can try and punch the bit out from the hole the ball sits in. If it doesn't come out like that then you would probably have to take the gearbox of and remove the striker from the tool holder and punch it out from behind.
Oct 21, 2008 | Dewalt D25830K 12 lb. sds max demolition...
1,344 people viewed this question
k24674
jasbo
jasbo
