Question about Canon Office Equipment & Supplies
Printer pixma mp 250 - printer does not pull the paper as it should
    Genius:
  • 1,669 Answers
Open up the areas where the rollers that push the paper are and thoroughly clean the rollers with rubbing alcohol...they probably have slippery paper dust on them.
Posted on Jan 12, 2013
  • 29 Answers
SOURCE: printer will not feed paper / message E2 ...cannon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
Posted on May 08, 2008
  • 49 Answers
SOURCE: Canon printer PIXMA MP 150
I think this may work.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Posted on Jul 03, 2008
SOURCE: reset my printer canon pixma mp 160
reset-mp160
Posted on Oct 28, 2008
Fame_Guru
  • 483 Answers
SOURCE: I have a Canon MP 520 Pixma printer and getting error code 6000
There is got to be a paper Jam inside the printer OR
Look for something that might have stuck up the roller ..
Thanks
Fame !
Posted on May 02, 2009
SOURCE: how to open canon pixma mp 610 printer to remove
The paper is blocked
Give me please a solution
Thank you
Posted on Jul 15, 2009
My canon MP 250 p.s.c. does not give good quality prints, they are muddy & not sharp
Try reloading the papers as well as cartridges. Please use the papers that are compatible with the cannon printer
Dec 11, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Cara mereset printer canon tipe mp 250... mohon bantuannya
bagaimana cara memperbaiki printer canon MP 258 Eror 5200 P08
Nov 05, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Just purchased a canon pixma mp 250 printer. pr...
The printer dosen't get ready after ON, it show half (0) on display screen.
May 20, 2010 | Computers & Internet
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 11, 2009 | Canon Office Equipment & Supplies
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My pixma mp 150 keeps feeding to the right only
its the common problem of dust getting blocked in the gears of the left side which pulls the paper.just get your printer serviced to avoid further damage.
Dec 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
24 people viewed this question
old marine
old marine
