Question about Alesis DM6 USB EXpress Kit Compact Electronic Drumset
Problem with dm6 and hiss problem
Hiss problem when hitting drums
    Genius:
  • 1,669 Answers
The amplifier may be turned up too high!
Posted on Jan 12, 2013
  • 7 more comments
  • RICH LAFORTE Jan 12, 2013
    THANKS BUT PROBLEM IS ALSO WITH HEADPHONES AT LOWER LEVELS
  • Leigh Perlmutter
    Leigh Perlmutter Jan 12, 2013
    Sooo, that is not the solution. Generally, the hissing in amplifiers is caused by a bad grounding capacitor at the amplifier output. It is there to ground unwanted ac interference. Check it out.
    THANKS AGAIN FOR YOUR REPLY,
    THANKS BUT PROBLEM HAPPENS EVEN WHEN NO AMP IS HOOKED UP AND LISTENED THROUGH HEADPHONES ONLYA
  • Leigh Perlmutter
    There must be a short in the output or the drum generator. Could be a hot transistor.
  • RICH LAFORTE Jan 13, 2013
    IF THERE IS A SHORT OR A HOT TRANSSISTOR WHAT COULD BE A SOLUTION.
    IF THERE IS HOT TRANSISTOR SHORT I WOULD LIKE TO RECIEVE A NEW MODULE AND CHARGE ME IF NESSARY AND CREDIT ME WHEN YOU RECIVE THE DAMAGED ONE .I HAVE JUST ALSO BOUGHT A NEW ALESIS AMP AND DONOT WANT TO WAIT 4 WEEKS FOR REPAIR
  • Leigh Perlmutter
    Leigh Perlmutter Jan 13, 2013
    I hope you are not thinking that I actually am going to do the repairs or exchange parts for you. That is not what FixYa is all about. It is just a free service to give advice and expertise about mechanical or electronic/electrical devices.
    NO , BUT THANKS FOR YOUR INPUT AND I WAS HOPING FOR THE ALESIS COPMANY TO ADDRESS THE PROBLEM AND THANKS AGAIN
How fix the firmware problems with alesis dm6?
Have you updated the firmware recently? If not, do so.
If you are having volume issues, you can adjust them with the following:
Adjusting the volume of individual pads:
-Press Voice.
-Then press Volume.
-Strike the pad you would like to adjust.
-Then use the + and - buttons to adjust the volume of the individual pad.
-To adjust another pad, strike that pad, and repeat step 4 above.
Aug 04, 2014 | Alesis DM6 Electronic Drum Set
I own an alesis dm6 mod. how upgrated firmware?
Click this to unload the latest firmware from the manufacturer!
DM6 Module - Firmware Update [v06]
DM6 Firmware Update Installer for Windows. Updated 04.26.2012
Fix'dYa
Can I use a 12V adapter to power the 9V output for my Alesis DM6?
No, it will work for some time, but will eventually overheat and cause damage. Spend the $10-20 and have piece of mind.
Jul 25, 2014 | Alesis DM6 Electronic Drum Set
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
Jan 04, 2013 | Alesis DM6 Electronic Drum Set
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
Have the alesis dm6 there is no out put sound. monitor appears to be working. hooked to small amp or headphones. just fuzz. please help. little guys christmas present!!!
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
Dec 25, 2010 | Alesis DM6 Electronic Drum Set
I own an Alesis dm6 mod. how to add cymbals.
I think your best solution is this> You can add 10 more triggers with it:http://www.alesis.com/triggerio
May 09, 2010 | Alesis Sr 16 Stereo Drum Machine
Alesis DM6 USB EXpress Kit Compact Electronic Drumset Logo
254 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
