Question about Epiphone Les Paul Studio Electric Guitar
Static Noise from guitar amp.
When I plug my amp to my guitar it sounds fine. But when I plug in my distortion pedal I get a static noise and I cant hear the guitar. The plugs are in the right place. I have a Spectrum stratocaster, a Spectrum combo amp, and a Danelectro FAB distortion pedal.
    Sergeant:
  • 238 Answers
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Posted on Jan 24, 2009
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
You may have a bad input or out put jack on the pedal you are using. It sounds like the Amp is okay, try using a different pedal and see if the noise still is present, if not, it was a bad pedal.
Posted on Dec 29, 2013
Static
are they hi gained presets (distortion)? if so, that woulld be typical of mast amps, However, polarity of the ground can amplify that white noise. most amps have a polarity switchfor ground on the back. if not you may be plugging into an older socket which doesnt have good ground. it can be resolved at the service panel. thats a whole different procedure. let me know
Mar 30, 2014 | Fender Music
Pa800 no sound
I'm not sure, but I believe this has a small sound card inside like in a pc and later model guitar amps. This card runs reverb and things like that and it also may have a small power plug going to it. I have found on many guitar amps that when this plug gets dirty, or possibly just a weak connection, they usually create static noises and then it echoes that noise. I hope this helps you.
Mar 04, 2014 | Music
My amp makes this static noise wich goes off as soon as i touch one of the strings or the metal part of the guitar cable. What can i do to make the noise disapear
This is a common problem... Make sure your amp is plugged into a three wire grounded receptacle. Keep the guitar away from magnetic fields of transformers in amps and effects units. Make sure you have a high quality guitar cable.
Sep 06, 2011 | Epiphone Les Paul Studio Electric Guitar
Hello i bought a Fulltone Clyde Standard Wah and it worked without any problems so far, but lately it started giving some kind of static noise when i turned it on and moved the pedal up and down. I had my...
The pot is generating noise. Some noise is unavoidable from pots. Using excess gain in the amp that that follows it will worsen the problem. If ypu can get to the pot and it has a way to squirt some CRC226 in it would help. You would have to use the spout on the can to squirt into the slot where the leads go into the pot. You can get CRC226 at Home Depot in the electrical dept.
Jul 20, 2011 | Fulltone Clyde Deluxe Wah Effect Pedal NEW
Fender blues deluxe reissue is making a popping sound
Try tapping the tubes (especially the small ones) lightly with a regular wood pencil and see if you can detect noise. Also verify your guitar AND cable are not the source of the noise by using them on another amp. Verify that popping exists witout guitar cable being plugged in.
Also this is the season for static electricity. Shuffling shoes on rug may create pops due to discharges. Spray rug with Staticide if this is the case.
Mar 13, 2011 | Fender 2232200000 Blues Deluxe Reissue...
When i shake the guitar i hear static sound thru amp. sounds like a bad ground. how do you remove switch, jack and pots to check connections?
LIKELY this is a TYPICAL poor connection at the jack. It is not uncommon to have slight noise IF the plug moves as you shake it.
AS A test, restrain the plug so it can't move.
Another source is a FAILING instrument cable. Get ones with GOLD plated ends as they are less prone to oxidation.
ONLY open the guitar after you have exonerated the cable. The jacks do wear, but more commponly the cable is at fault. The connections inside are USUALLY solid and NOT a problem.
If you can access the jack, you could increase the spring tension.
First though, see if moving the plug where it plugs in creates noise.
Oct 09, 2009 | Gretsch G6120 1959 Chet Atkins Hollow Body...
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Getting Static noise when plugged in to amp
This is a very common problem that I have repaired for many friends. Sometimes the guitar jack becomes loose and gets rotated to the point where the wire breaks and/or touches the cord plug when it's inserted into the jack. You need to remove the access plate/panel at the back of the guitar body and see if the wire is broke or twisted. You may only have to loosen the jack retaining nut and rotate the jack to get the twist out or you may have to remove the jack and resolder the wire back in place. If its broke make sure to solder back on the proper terminal--the one with solder already on it and not the one that the cord plug touches when its inserted. Retighten the jack nut by firmly holding the jack from access side so it doesn't rotate again and cause that undesirable STATIC sound. Hope this helps.
Dec 08, 2008 | Epiphone Les Paul Studio Electric Guitar
Epiphone Les Paul Studio Electric Guitar Logo
1,662 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Robert Graf
Are you an Epiphone Music Expert? Answer questions, earn points and help others
