Question about Hannspree HT09 28 in. LCD TV
Hannspree 28" tv video shuts off after on for a few minutes
Our tv is about 2 years old and started shutting off the video after it is on for a few minutes. Audio seems to work ok and we tested the cable connection and it is fine.
    Top Expert:
  • Hannspree Master
  • 75,471 Answers
It sounds that the fault is with the connections that goes to panel from its T'Con board. Check all the flat cable connections. Re-seat them once.
Posted on Jan 12, 2013
5 Suggested Answers
  • 19 Answers
SOURCE: Hannspree xv 32 no power just shut off
replace power supply. I just had my done and there is an upgrade kit for it. I paid $205.00 to get it done.
Posted on Sep 08, 2009
  • 4090 Answers
SOURCE: TV doesn't receive signal
Faulty Video boards If you bought it in May then rapidly get it fixed under warranty or exchange it for a better brand. Who is Hannspree? not well known and may be cheap Korean TV with no parts available
Please rate our help to keep FREE service online++++Thanks for using FIXYA
Posted on Sep 12, 2009
SOURCE: can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Posted on Dec 01, 2009
SOURCE: hannspree not working with remote. original remote
same problem as above help
Posted on Oct 30, 2011
Have an LG 50PN6500 plasma that’s 4 years old. Picture is still great, but last year it started powering off by itself for a few minutes at a time, then it would turn back on. We took it to the local LG...
Some components in the TV, and most likely in the power supply are starting to become temperature sensitive. Some Capacitors tend to become this way when they age. To find the temperature sensitive caps that are failing it will take a very experienced TV or electronics service person with a supply of liquid air and a heat gun to thermo test. He will also require the proper test equipment to verify. The big service centers should be able to troubleshoot for this, but the time involved and the cost of the parts will be expensive. If the set is out of warranty, it would be more feasible to get a new one!
Dec 30, 2017 | LG Televison & Video
My laptop doesn't have a HDMI port so I have to connect with two cables...I think ones VGA and the other is audio. This goes into the back of my old smaller tv...which is ok but I'd like to route the
Your TV doesn't have video output on either HDMI or Composite video. (There are a few TVs that do have a video out but often that is only available for some input/output combinations. You would need to check the manual but the PC input is usually not available for the video output.)
You could get a VGA to composite or component video converter and direct the signal to your new TV from your PC. One example of the first converter is here: http://www.cablestogo.com/product/29548 . An example of the VGA to component video is here: https://sewelldirect.com/audio-authority-vga-to-component-pc-to-hdtv-converter.asp . There are other models available. A few VGA to HDMI converters also exist. However, since those need to convert an analog output to digital, they are more expensive.
I hope this helps.
(A few VGA to composite cables exist. They will not work for your purpose. They are designed to connect projectors with RCA ports and understand the VGA RGB signal to a computer.)
Jan 15, 2015 | Computers & Internet
Insignia lcd tv shuts off after 2-3 seconds
The TV seems to have a failing Power Supply. This could potentially be repaired but would be an out of warranty expense.
Dec 14, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Hannspree HANNspree HANNslounge 32" LCD
I would get the TV replaced under guarantee. There maybe a loose wire in the power supply or invertor stages that is arcing and burning
Jan 02, 2018 | Hannspree HANNslounge 32 in. LCD HDTV 32
TV turns on for few minutes than shuts down and comes back on for few minutes and shuts down again. can you help me understand where to start
Hi it looks like you have a bad ballast issue or bad lamp this lamps are rated 6000-8000 life hours that equal to 2-4 years of use so if your lamp is around that old it could be that the lamp is burning out but if you have a new lamp and get this issue then the problem will come from the power source of the lamp witch is the BALLAST BOARD that it might not be able to maintain the lamp on I would start with the lamp if it is a old one all ready
http://www.discount-merchant.com/SearchResults.asp?Search=HLN617W
Sep 14, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My HannsG 28" (HG281D) shuts off the screen intermittently, as if it were overheating and was self-protecting. Power light remains on and steady. I can turn it off and wait a few seconds, when I turn it on...
That happens when the ballast transformer for the backlight overheat. Backlight or cold cathode light function is responsible for the images that you see in the screen.
Unless you are capable of replacing by yourself the parts with the same value and you have the right tools and skill to do it your own.
Otherwise, I suggest you bring your monitor to a credible technician.. or if the unit is still under warranty you can bring that to their service center..
May 20, 2010 | Hannspree HannsG HG281DP 28" LCD Monitor
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
Sony STR-DE925 auto-decode has worked fine for years. All DVD/PS3/Cable is attached to TV via HDMI and inbound audio from HDTV is optical fiber (TOSLINK). Up until today, this has worked perfectly, i.e.,...
OK, so with more troubleshooting, I was able to eliminate the problem with my DE925. It was actually the Vizio HDTV that was causing the problem, as I decided to route the optical audio from my DVD and PS3 directly to the same TOSLINK port on the DE925 and auto-decode worked. It was not the fiber-op cables either. This HDTV was a less-expensive 720p 32" model anyway, so I am not too concerned with the optical out working on it as I can run up to four TOSLINK connections in to the receiver.
Jan 02, 2010 | Sony STR-DE925
Ford F 350 with 7.3 has batteries going dead
the dome light is draining the batt.
pull neg batt cable off when truck is running to see if the alternator is working correctly. check that glove box, hood,trunk/cargo light is shutting off when they should be.
Oct 02, 2009 | Ford F-350 Cars & Trucks
Hannspree HT09 28 in. LCD TV Logo
220 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
