I need a manual for celestion src1
Connection to speaker
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
Replacement tweeters
TIP
Why not go for replacement diaphragms for the ones you have ?
Its not realy difficult to do it yourself
celestion a2 tweeter blown or not
http://reconingspeakers.com/product-category/diaphragms/celestion-diaphragms
Jul 26, 2013 | Celestion A2 Speaker
No sound from Celestion F20 subwoofer. Tweeter is OK, and so is the other speaker in the pair. Wiring OK as switched speakers around to test.
Since these can be bi-amped or bi-wired (and you don't indicate if that is the case) you need to make sure the jumpers are secure (see the last picture http://archiwumallegro.pl/celestion_f20-1062028198.html) or (if the jumpers are removed) that you have viable amplifier signals coming to each speaker within the cabinet.
May 30, 2011 | Celestion F20 Main / Stereo Speaker
The adjustment plate is broke on my MP1. I need to replace it. where do I get parts?
Please contact KEF/CELESTION Service Department on 01622672261.
Jan 15, 2011 | Celestion MP1 Speaker
Connecting Celestion S1i Subwoofer to a laptop is this possible?
Attach the audio out or headphone out of your laptop via a suitable adapter to the RCA Line In and whatever other amplified speakers you might have to the Line Out according to their needs.
Dec 22, 2010 | Celestion S1i Speaker
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Celestion QXa 152 PA speakers
Well, if you can manage to open it and check for a "blown fuse" and change a good one... if it works ... you are lucky. I'll hope and pray that it's only the FUSE.
Jan 02, 2008 | Celestion 1525E Coaxial Car Speaker
139 people viewed this question
 Grubhead
Grubhead
