Hi i have a panasonic amp which dosent power up i have done some cold checks and found one of the 4amp fuses blown so i replaced and it blew amp is still dead no power i suspect the transformers gone??can any one help?.
  • Audio Player... Master
  • 5,056 Answers
Fuses blow because of an overload. I suspect you are looking at the wrong place in the transformer and power supply. Instead look at the main power amp board on the things sat on the heatsink, they will be the cause of the overload. If they are transistors you will find one or more with a short circuit, with a simple test with an Ohm meter. Just connect the leads to the terminals of the device. If you find one where it's like touching the test probes together! You have found the faulty part.
Posted on Jan 16, 2013
kimberleykid
  • 5 Answers
SOURCE: Channel short
Hi there, sounds like you may have a short to ground on the output transistors. Does it have transistors or an IC output. It is most likely that you have not replaced a mica washer or insulator. Check to ground with a meter from the case of the output devices.
Posted on Aug 28, 2007
SOURCE: pioneer m-770 will not turn on
you probably have a short in the circuit some where. you need to replace the transistor and look at all the solder joints to make sure there not damaged or cracked. i have the same amplifier and i replaced the fuse several times and it blew every time up until the last time when the 4 of the power output transistors blew. what ever you do do not try and power it on till you do all the things i told you or you will have sparks and fire. my mistake cost me my amplifier. but might help you get yours repaired
Posted on Dec 24, 2007
  • 4 Answers
SOURCE: NAD 370
Hi There is no circuit breakers inside. close to front panel on a left side under plastic cover is fuse (AGC type) . Before you change fuse look at four filter capacitors in the middle of unit!!! (close to power transformer on pcb) If they are white do not change the fuse and get unit to good service center( it must be someone who knows what they doing!!!) If the caps are different color (black ,purple) you can try to change fuse. Once again if capacitors are white do not use unit-fire hazard!!!! I'm long time service guy for NAD so trust me on this one Dariusz  dariusz70@verizon.net
Posted on Feb 13, 2008
  • 4234 Answers
SOURCE: Bose SA-3 Amp / Blown Fuse
The problem is not the transformer. You now have shorted output transistors at the very least. By corssing the wires you presented a zero(0) ohm impedence load to the output section. It quickly went into overload. Before the fuses had a chance to open up, the outputs fried. This unit will require new output transistors and perhaps the previous driver circuit will require parts as well. Figure on $20-$50 in parts plus hte local labor rate for the repair.
Dan
Posted on Oct 01, 2008
Grubhead
  • 5056 Answers
SOURCE: Loss of audio output right channel
Take a look inside see if the amp uses transistors or an IC. If it uses transitors you can put a Ohm meter accross the leads (no power on) If it reads 0 (digital meter) or the pointer swings full over on the leads of any the transistors it's blown. If an IC then the thing might look damaged.
Posted on Jan 27, 2009
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Why tcl42u22 has no power
Panasonic tc-l42u22 4amp fuse blows replace 2 diodes nte#116 or nte 552 600v 1 amp silicon rectifier fast recovery
May 10, 2014 | Panasonic TCL42U22 42 in. TV
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
The mains input fuse (4amp) and a (1amp) fuse on the main power out board were blown. Replaced fuses and switched on, blown again, disconnected output from transformer to main board (4amp) fuse did not...
The cheapest option is to replace the transistors (a quick check on google will tell you how much they are). If they are common transistors you will be able to find them and get them quicker then searching for a board that could be no longer being made.
Sep 02, 2010 | Mackie SWA1501 Subwoofer
Fuse keep blowing
Means that item the fuse is protecting is bad.Fusing unit is a good start replace it
Apr 01, 2010 | Office Equipment & Supplies
Subwoofer Repair
replace the sub and if it has a built in amp you may want to check the amp as well
Oct 10, 2009 | Logitech Z-5500 Computer Speakers
Panasonic NNA554W blows 10a fuse when microwave comes on
Possibly the interlock monitor switch is bad or out of adjustment. This switch is designed to create a short circuit across the power line (and then blow the fuse) if you attempt to defeat the door interlock and operate the oven with the door open. A shorted capacitor or diode could also cause the fuse to blow. Because of lethal voltages inside and the possibility of microwave leakage if repairs aren't done correctly, you are best off leaving microwave service to professionals.
May 15, 2009 | Panasonic NN-SN657SMicrowave Oven
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
Blown fuse
check mcm electronics, if the fuse keeps blowing you have bigger problems.
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Sylvania 6632 LG blows fuse when plugged in
I too had this problem. I read some posts on this site about how to repair it, and low behold, they worked! I took the back off of the TV, and the first thing I found was the fuse was blown. With my meter, I checked the first 1N5406 rectifier diode after the fuse, and found that it had shorted out. Then I had to learn to desolder the diode, which I learned about on Youtube. I bought a pair replacement diodes at Radioshack for $1.49 and four replacement 125 volt 4 amp fuses. The whole repair cost about $5.00 and a few hours about learning about electronics. The TV works great! Good times!
Jan 24, 2008 | Sylvania 6632LG 32 in. LCD HDTV
18 people viewed this question
 Grubhead
Grubhead
