Question about Refrigerators
Westinghouse Virtuoso model BJ503T-R compressor keeps running non stop. Started after an extremly hot day
Freezer coil frosted over which i turned off fridge to manually defrost and since i turned it back on compressor runs nonstop and gets hot
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
philbran
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
  • 5 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
SOURCE: westinghouse silhouette frost free 522 fridge is
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Posted on Jan 01, 2010
  • 4 Answers
SOURCE: westinghouse virtuoso fridge freezer on top has
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Posted on Oct 13, 2010
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
Why are the sides of my upright freezer hot and the compressor very hot
Good Afternoon Friend,
I understand the sides of your Frigidaire freezer are hot and the compressor is very hot. I also see that the drain plug was frozen and the coils had lots of frost, which you defrosted and your freezer began running again. It looks like your freezer quit again and started up, leaving everything hot. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to be hot. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Freezers
Alarm keeps going off on Westinghouse virtuoso. Just recently moved and since then it keeps going off every 20- 30 mins. The freezer temp is constantly flashing but not sure what to do??? Help it's driving...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | Refrigerators
Hi Side by side refrigerator not cooling down. Freezer seems to be not freezing. refrigerator compressor is running. Freezer damper wide open on a setting, refrigerator turned up to 10, running but not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
jkkfj
Jul 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
My fridge is not cooling,it is a kenmore 596.58642890.we un pluged it for about 5 days with the doors open to try to defrost it,we checked the seals and they are ok,the compressor is running as well as the...
I have a little question about the defrost. Did you see frost build up on the rear panel of the freezer. Is there no hot line coming from com compressor to condenser coil or cold from evaporator? Waiting on your answer, Sea Breeze
Nov 22, 2009 | Refrigerators
My GE side by side refrigerator quit working.
The automatic defrost system is not working. All frost-free machines have a heater in the freezer to melt the frost away on a timed schedule. Every day or two the defrost cycle is initiated by the defrost timer. A heater melts the frost, then the cooling system is turned back on.
Mar 06, 2017 | Refrigerators
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
PDS22SBRLSS
Hi is there any ice built up at the back of the freezer. is the fan motor going if no ice or frost build up in freezer and fan motor is going . check the compressor. thanks the appliance doc
Mar 09, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
