Question about Hitachi 32LD8700 32 in. LCD Television
The picture is purple haze like a marble effect
    Top Expert:
  • Hitachi Master
  • 74,211 Answers
Absence of Green is the fault. Check the connection wires [flat cables] connected between panel and T'Con board for any loose contacts. Re-seat them.
Posted on Jan 12, 2013
Camera works,all lite up and functions work
Purple haze usually indicates an image sensor failure. However, the fact that it only does it with one of your lenses is strange.
May 01, 2013 | Nikon D70 Digital Camera with 18-70mm Lens
What effects did jimi hendrix use on purple haze?
he uses a wah wah pedal, heavy fuzz distortion, and an octavia pedal for the solo
Jan 29, 2013 | Audio Players & Recorders
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
When I print the picture has a purple haze in it ?
If you are using re-manufactured ink tanks, that would explain it, a mi-matched ink tank. To clarify the ink colour is not quite right.
If genuine ink tanks (Recommended) then maybe try different paper. If using photo paper you should be using compatible / genuine paper as the different chemicals react can give this problem.
If using fax / standard paper then could be print head fault....normally get an error code.
Jan 26, 2010 | Dell P703w Printer
Purple/pink haze on a samsung tv
is it a tube or flat screen? if tube could be sign tube is going bad- can try to degauss it- if its a panel does the picture look cartoony? we call it solarization- may be a problem with settings in the service mode- may need new main board
Aug 19, 2009 | Televison & Video
Purple haze and everything is distorted to the point that picture turns out to be a blob of purple
CCD FAILURE !
Call Canon for FREE REPAIRS
See Advisory it is a known manufac fault just call them
pls rate me well
Aug 10, 2009 | Canon PowerShot A85 Digital Camera
Lumix FX12 LCD screen shows purple haze
raegag
wsd*g
jagskfsda
vwomcjcwkjksdfs;adjkfksjcvijsiarue45646514sd5v13sd4f86vaf21g623g4f861++-+sv+svgsfgsg+fgasvcsdgwg
the answer is 123456789654321456789654123 dota boysssssssssss
Jan 16, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Pink/purple melting effect
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 26, 2008 | Canon PowerShot A85 Digital Camera
Screen shows a fuzzy purple haze
unistall it and then restart computer works like a charm. dont reinstall it, cause for some reason it comes back up when restart it
Nov 18, 2007 | Toshiba PDR-5300 Digital Camera
Hitachi 32LD8700 32 in. LCD Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
