Landis+gyr credit meter red flashing meter lights
What do the flashing lights mean and are there any other colours than red
5 Suggested Answers
gwbm
  • 353 Answers
SOURCE: Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on Mar 12, 2009
SOURCE: ideal classic boiler no heating only hot water
Hi I have some boiler problems, I`m the proud owner of an Ideal classic SE12ff. The controls are that of Sunvic select Xl.
The problem is I can only get the hot water to work when the heating is on, I neglected this over the winter but now the summer is apparently fast approaching I am desperatley trying to get this solved. A plumber has done some fault finding with no prevail, have you any suggestions?
Posted on Apr 23, 2010
  • 10865 Answers
SOURCE: Landis & gyr sel 61.6
Hello brooksindele. Go to this link and click on support
http://www.landisgyr.com/na//en/pub/index.cfm
That way you can ask Landis and gyr directly for the diagram you need. Joe
Thanks for choosing Fixya!
Posted on Nov 27, 2010
pctech1
  • 1940 Answers
SOURCE: Hi there, I am looking
Here is the manual for the Landis & Gyr EM1200:
http://www.countryenergy.com.au/asset/cms/pdf/contestableWorks/CEOM8014_53.pdf
I could not find a manual for the EM1000, but this should function similarly.
You could also submit a Request for Information to Landys+Gyr for a manual for your EM1000 here:
http://www.landisgyr.com/en/pub/contact/request_for_information.cfm
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Mar 31, 2011
Landis gyr meter manual
computer software ?
PDF]User Manual - Landis+Gyrwww.landisgyr.eu/product/map/?download=78003
Apr 29, 2017 | Cars & Trucks
I have a gas meter and pay as I go card but the machine will not accept my card , what do I do "?"
Call the card companie and see if you have funds on the card. Sometimes I think I do and then I didn't realize the fees ate it up. Or they could have shut off your card.
Jan 04, 2015 | Siemens Landis & Gyr 536 765
While I was charging the power chair all the indicater lights came on and with a block lights went from all green to 2 red flashing lights, w/ 2 red lights flashing I stopped and shut it off 4 five se
Two red lights blinking means the electronics on the chair think the batteries are low. Test the voltage on the holes marked 1 and 3. Hole 1 is positive and hole 3 is negative. Your meter must be set on DC volts and the meter leads must be in Common and Volts. If your meter has to have the voltage range set, put it on 200vdc. The red lights will blink if the voltage is approximately 22.5vdc or less. The green lights turn on about 24.5vdc or higher.
Sep 18, 2014 | Invacare Pronto M51 Power Wheelchair
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
How do i reset a landis prepaid meter
You do realise that the itme you are asking about is not a computer motherboard, don't you? It is a heating system controller.
Apr 21, 2013 | Siemens Landis & Gyr 536 765
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
Wiring honeywell to old landis thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jul 08, 2009 | Honeywell Heat/Cool Thermostat
Colour cartrige not work epson stylus c66
If the red light is flashing it means one of your inks are low
Nov 02, 2007 | Epson Stylus C66 Inkjet Printer
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
