Question about Avid MBOXPTEX-EDU Mbox Protools Express -
Why do I keep getting a hardware not found pop-up even though my mbox mini is installed, connected and shows up as a driver on my pc?
When i plug in my mbox mini 3 the blue light come on, but when i try to lauch pro tools it says that hardware is not recognize. When look at the mbox mini control panel, it says that it is not connected...
Assuming you are on a Windows system, go to Control panel/Sounds and devices/ and check that the Mbox2 appears as the default in the Audio and also Voice tabs/panes while unit is connected. If it is not, select it in each... if it is not in the list offered, then the drivers have not been installed for the Mbox.
Aug 24, 2011 | Digidesign Mbox 2 Mini Workstation
Pt wont see my mbox
need driver for ct4670 sb!tnx!
Oct 09, 2009 | Digidesign Mbox External Sound System
Multiple audio noises even when mixer faders are down
100% raidiation problem!
it was wid my denon protech also,
see if earthing is correct for all gears,
try keeping an equidistance of 10"inches between each gadets
May 25, 2009 | Digidesign MBox 2 Mini (USB, includes...
Digidesign MBox 2 micro doesn't playback sound from windows vista
make sure that windows recognizes it on your hardware devices...right click on My Computer and go to properties...clck on the hardware tab and click on Device Manager....makes sure that all Yellow Exclamation points are resolved and that windows has installed their drivers etc by clicking on them and updating driver...you may need to specify the location of the drivers whether they are on disk or on your computer somewhere...after this is done...try going back into the sound properties and seeing if the newly installed device is coming up...
Apr 08, 2009 | Computers & Internet
Can't get my mini mbox usb working for protools 8 after inserting
You were supposed to install the software first (which holds the drivers for the hardware) before you plugged in the MBox. I had the same problem, but I had to use drastic measures and reinstall my OS.
Mar 29, 2009 | Digidesign Command 8 USB Control Surface...
Digidesign Mbox on Vista
same here but when i pull up protools the mbox does not power on !!I have the imac g5
Jun 21, 2008 | Digidesign Mbox External Sound System
PROBLEM KEEPIN MBOX 2 CONNECTION TO MAC LAPTOP
I have the same problem. Usually it will work when I reboot the computer. The trick is once you get the mbox working with the phantom power on, is to not turn off the phantom power during your session; the duration in which you use the mbox at that given time before shutting it down. You can switch the phantom off and it won't shut off, but if you press it back on, it may and for me more than half of the time it does shut off. I have a new problem with my mbox. I can't hear play back, even though I can hear sound from either input. Any suggestions?
Oct 26, 2007 | Digidesign Mbox 2 Barebone
Problem installing the driver
Mine did the same thing - just ignore it and click ok - it will work believe me - just do it and it'll work.
Sep 12, 2005 | Creative Labs PC-Cam 550 Digital Camera
Avid MBOXPTEX-EDU Mbox Protools Express - Logo
23 people viewed this question
Top Avid Computers & Internet Experts
Michael Galve
Michael Galve
castletech
castletech
Are you an Avid Computer and Internet Expert? Answer questions, earn points and help others
