Question about Symphonic WF-719 19 in. TV/VCR/DVD Combo
Dvd player will not open.
Hello... my DVD player will not open on my combo TV. I am pretty good with electronics, so I opened it up (unplugged it, but was still careful because I know TV's are dangerous regardless). On of the gears busted off. Where can I order a replacement DVD player? Thanks Tammi
  • kajmahal Jan 31, 2008
    I openned it up & found that the gear to drive the tray had broken off. Can I get a gear or another DVD assembly?
  • Anonymous Apr 05, 2008
    my dvd player wont work and it keeps scratching my dvds
I figure that even if I can repair this, the time and money spent to do it will exceed the cost of a component DVD player that I can get from a supermarket. Besides I doubt if the quality of the repair parts will be any better than the original parts.
Posted on Jan 31, 2008
Hello I have an Isis tv and unfortunately my to control is not working , I have got it stuck on dvd mode is it possible to change it back to tv by the buttons on the tv?
TV built in DVD
Just for you Sapphire Lopez,
I went out ... into the quite bizarre ... cold cruel world of DVD/TV combo sets ... If you don't have your owners manual... either reveal it to us or put it plus your model number on the internet...
manualslib.com seems to be pretty good
One person stuck a post card in & got it to trip... FRANKLY... Unless you are ready to TRASH your unit... that'd be a no no...
Disc readers are pretty fragile ...
Another recommended unplugging for 5 minutes...
I'd sugest
flash-light... and look real closely around the edges for menu or the eject button
Buy that new remote
Look over the old remote:
Clean the contacts with a soft graphite pencil "lead"... or a tiny bit of white vinegar on a Q-tip
(dry all excess).
Put a tiny but of lithium grease (or even Vaseline) on the metal
(wipe away all excess)... Insert fresh batteries & give it another try (if for sure its dry.... only a matter of open air (no batteries).
(if you put in a specific TV/DVD model...
it did NOT make it out this end )
Comment me back... I can expound voluminously... as you prefer
ManualsLib Makes it easy to find manuals online Carnac the Magnificent
Apr 09, 2016 | Televison & Video
Coby TV/DVD Combo
my dvd 's will not go into slot. Dvd says it is closed and no dvd. I have unplugged tv, opened and closed dvd and it will not open. What do I do?
Nov 06, 2010 | Coby TF-DVD1540 15 in. TV/DVD Combo
The DVD drawer won't open and close on our Go Video VR3845 combo. Help.
Straighten a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Z
Dec 31, 2009 | GoVideo VR3845 DVD Recorder/VCR
I have a JVC DVD- VHS Combo Player. Model #
Unplug it and wait 5min plug it back in and sometines it will work, I have three units they all do the same thing , with two of them the unpluging no longer works. I can't find anyone who knows whats wrong either
Sep 05, 2009 | JVC HR-XVC30U DVD Player/VCR
DVD PLAYER WON'T OPEN
Do you see the open close icon ont the screen? Do you hear any motors running? Most common problem for this is the mech jumps time
Jun 17, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Rca dvd\vcr locked on hello
The hello issue is most likely a faulty DVD-RW. These go out on thse models more than usual. Reset is a combination of 2 buttons. Press and hold the play and disk tray open or the power and play ( i forgot the exact sequence but you get my drift, press 2 buttons for about 10 seconds). You can also update the firmware...or atleast could before from RCA.COM but they no longer support this midel. I do have the software update on CD but it won't do any good on Hello issue. If worst comes to worst, open the player up and replace the DVD-RW drive.
May 25, 2008 | RCA DRC8060N DVD Recorder
Toshiba tv/dvd combo
Hi there!
The drive belt that controls the tray probably snapped. Not sure about the mech on your set, but you can try and see wether you can lift the front cover of the tray slightly. Check to see if you can see a gear inside, using something thin you can try to manually turn that gear from right to left or the other way until the tray opens just enough for you to pull it open. If this is not possible, please refer to a repair technician. Please unplug mains from the wall before you check. Good Luck, Regards, JUS004
Mar 23, 2008 | Zenith SY2549S TV
Dvd
I had to unplug mine from the wall, then make sure the TV is off, and hit the open button.
Mar 09, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
No power to DVD combo player. VCR OK.
The power circuit for the DVD and the vcr are separate look for a open diode and transistor in the circuit that supply the DVD.GOOD LUCK.
Apr 26, 2007 | GoVideo Go Video DVD/VCR Combo
DVD drawer in TV/VCR/DVD combo won't open
Hi, The problem may be mechanical or electronic. If the drawer is stuck from being bent or jammed it is mechanical. If the system controlling IC circuit is defective, then it is electronic. If it is still under warranty the factory should be responsible for it. If it is not under warranty, the cost of repair is likely to be more than the price of a new dvd player! Sorry, Daniel
Feb 16, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Symphonic WF-719 19 in. TV/VCR/DVD Combo Logo
93 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
