Question about BenQ Projector Lamp for MP510
I replaced the lamp (buld) after hours of the previous came to an end, but the message says 'replace bulb, 3,000 hours have finished' is still showing on the screen. Please advise how to remore the message
    Genius:
  • 2,432 Answers
You have to reset the lamp hour in the settings.
Posted on Jan 12, 2013
Nec vt695
Did you unplug it before you replaced the bulb?did you touch the bulb?are you sure the bulb works?have you reset the lamp hour meter?did you replace all doors, screws and original parts?is the bulb securely in place?
Here is your manual http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
Mar 29, 2013 | NEC VT695 LCD Projector
Message on screen-The bulb has reached the end of its usable life....and it has 97 hrs left and can't clear the message.
select Menu>>>[default]>>>[Clear Lamp Hour Meter]. do this after replacing the lamp.
below is a link to the manual. what you seek is on pgs E-30,31. Good Luck!
http://www.support.nec-display.com/dl_service/data/manual/english/vt660k_e.pdf
Sep 13, 2011 | NEC VT460 Multimedia Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Cannot reset lamp counter on benq mp620 projector, projector bulb has been replaced but lamp counter warning is displayed on startup and requests buld change and reset of counter. So I'm stuck in a...
Hi, I don't know if this is to late but oh well, hold down the exit button on the projector panel for 5 secs, and then press auto on the same panel after, this should reset the hours back to a lovely zero
May 26, 2011 | BenQ MP620p DLP Projector
My ask m3 projector powers on but doesnot display anything. No light comes out of the bulb. Is it possible that the projector's bulb hours are finished?
Very possible. Replacement lamp:
http://www.shopvsc.com/Ask-Replacement-Projector-Lamps-s/135549.htm?searching=Y&sort=7&cat=135549&show=50&page=1&f-M2+=135515
Oct 03, 2010 | ASK Proxima ASK M3 projector lamp...
MD5880N replaced bulb and worked for 2 hours now nothing
Place heat shielding around the lamp to prevent overheat; use cooling spray (freon) to cool any chips or, circuit boards near the lamp as you attempt to start the set check the lamp for the correct serial # voltage etc.
Aug 02, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Need new bulb and what ever goes with it
here's a link to the manual...
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/PD525-_E
and here's a link to find you a lamp ;) the lamp/lamp holder is an integral unit with this projector (and most others...). There are plenty of folks that sell replacements...usually $200-$300 since the unit has been discontinued.
http://www.google.com/search?q=acer+pd525+lamp
for what it's worth, I have one at work and at home and both are workhorses...aside from lamp replacements every ~2,000-3,000 hours, they've both run very well.
good luck,
shep.
anisotropic.us
Mar 07, 2009 | Acer PD525 Multimedia Projector
Sony grand wega KDF-E50A10
The looks of the bulb are no indication that it's okay. How many hours of operation do you have on that bulb? The bulbs are average rated for 5000 hours, but its been my experience that they usually last on average 3000 hours. Try replacing the bulb and then check and rest the buld hours counter.. Best place I've found for purchasing the bulbs is DLP lampsource. They'll sell you just the bulb without the housing at a dramatic savings. http://www.dlplampsource.com/
To display the lamp time press [ 2 ] nine times.
to reset press [ 3, mute, enter.] Or with the set in standby press [ display, 5, vol up, power ]
then press [ jump 3.]
Hope this helps!
Bill
Dec 01, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Short life for a Sony LMP-150
The bulb replacement message is not triggered by bulb condition. It comes on after a given number of hours use. If you did not re-set the hours counter to zero when you replaced the lamp then you will get this message prematurely. Don't replace the lamp until it ceases to work correctly - colour balance wrong it it simply does not light.
Oct 16, 2007 | Sony Office Equipment & Supplies
BenQ  Projector Lamp for MP510 Logo
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
