Question about Dual XDV8125
What do all hook ups do
Im going 2 hook up all kinds of stuff before i put it in dash..like whats blue sub wire?..doesnt subs get hooked 2 gray rear wires?..and front black wires are for what?..and what and how can i hook 2 tv screen on deck
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Dual Master
  • 102,366 Answers
You may download a copy of the installation/owner's manual here. The wiring diagrams begin on page 4.
Posted on Jan 12, 2013
  • 4 Answers
SOURCE: remote wire
there should be a remote wire for your amplifier on the back of your stereo if you have an aftermarket stereo. It's usually a blue wire, if not you can always hook it to the same remote wire as the one your stereo is running off of.
Posted on Dec 10, 2008
  • 33 Answers
SOURCE: Amp or Stereo Cutting out...
I agree with what you think it might be. I really think its the deck that is bad and you should be able to take it back for a new one. Have you tried unplugging the RCA cables to the amp to see if that stops it? That would tell you if the amp is backfeeding or doing something weird.
Posted on Mar 02, 2009
mikehitchner
  • 28 Answers
SOURCE: Dual XDV8125 car stereo wiring
The best way to be sure is to get the car stereo installation plug for your year make and model car and wire that to plug for the back of the stereo then plug the installtion plug directly into the factory plug of the vehicle.If this is not an option then try to locate the dimmer wire (usually orange but this differs depending on vehicles so be careful).Also usually the wiring codes are printed on the radios top or bottom.Usually the dimmer wire controls the LCD power.
Posted on Apr 12, 2009
  • 8 Answers
SOURCE: stereo system in 1994 ford explorer
I had this same problem.Took it to a friend and we bypassed the amp completely and ran new wires to all the speakers.
Posted on Aug 29, 2009
  • 733 Answers
SOURCE: How do I turn my subs on on my xdm7510 radio
check to see if you have power going to the amp. Battery(+) and Negatve(ground). if those are ok, turn the radio on and check to see if the remote wire(it's usually blue) has power. if you have power on the battery wire and the remote wire from the radio, then there is a problem with your amp. check fuses on the amp if any.
Posted on Sep 07, 2009
Blue power antenna wire is causing radion to stay on all the time what should I do
The 3rd wire is coming from the bypass switch. I have the solid blue wire from the unit the blue and white from the jeep and the bypass wire all hooked into one. Is there another wire I could hook the Blue wire too I had two yellow wires coming from the radio one is with the yellow wire from the car the other is capped off could I unhook the blue from the blue and white/bypass and hook it to the other yellow possably?
Apr 15, 2014 | Pyle PLTS78DUB Car Video Player
Im trying to run two kenwood 6/9,s and a mtx sledge hammer 12'' sub of a mtx 6004 amp.where do i put my rca,s front or rear / and if this is poss how do i bridge the sub ????? im lost
Im kind of confused with what exactly your asking. Are you trying to run 3 subs off of an amp? If so, the RCA's should go to the front of the amp, and if your plugging 3 subs in to it, you need to have a 3+ channel amp. There is a way to hook it up differently though. I have 4 12" Hifonics subs running off a 2400 watt Nitro-BMW-486 amp. I just have two subs running to each of the two channels.
Sep 26, 2009 | Car Audio & Video
Jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Jan 28, 2009 | Jensen VM9510 Car DVD Player
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Amp to jensen uv8 hook up
to fix your problem cut the wire in half connect it to a ground and hot and there ya go it fixed my problem
Sep 15, 2008 | Jensen VM9020TS Car DVD Player
Powered subwoofer wiring
Red = 12v power Always
Black = Ground Allways
Blue = memory wire that has to run to a Amplifiers Memory Terminal
2x White, seems to be the dimmer and Ant, but im unsure as of these two,
Rca's will go into the AUDIO out of the cd player RED and White holes, that will go to your amplifier.
Im unsure if your talking about a Cd player here, but it seems this it is. If so you should have color coded wires for speakers also (ex- green, green with white stripe, Yellow, yellow with white stripe )
Please provide more information if this dosent solve your problem
Thank you
Sep 11, 2008 | Sony CDX-M610 CD Player
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
How do i hook up the r.c.a to the back of VM9312
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is on...you will blow amp
Mar 18, 2008 | Jensen VM9510 Car DVD Player
No sound comming from car speakers
What kind of car? What kind of system? More details will help me assist you better. If it is an aftermarket in-dash stereo, it sounds like the blue/white wire is not hooked up correctly. This powers up the car's amplifier and lets the sound through.
Sep 20, 2007 | Car Audio & Video
Dual XDV8125 Logo
47 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
