Question about HP Compaq 2510p Notebook
2510p keyboard Keyboard removal
    Sergeant:
  • HP Expert
  • 427 Answers
Http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01826778&prodSeriesId=3355633&prodTypeId=321957
Posted on Apr 17, 2013
How to unlock the touch pad
There should be a touchpad on/off button on the top row of lights above your keyboard. It is a square icon, tbh it looks like a small touchpad. If this doesn't work there may be a problem with a driver. In which case go here - http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3355636&
then choose your operating system. First try the quick launch buttons driver, then try the synaptics driver. Post back if this doesn't help
Mar 14, 2014 | HP Compaq 2510p Notebook PC
I want to safely remove, clean and replace all keys on the Dell 610 keyboard
HI michael so if you want to clean your keyboard so first you must take off the keyboard from you laptop .
Let's remove the keyboard. Insert a flat head screwdriver between the keyboard bezel and laptop case and carefully lift up the bezel. Remove the bezel.
You'll find two screws securing the keyboard. Remove both screws.
Now carefully lift up the keyboard. You'll see the default memory module under the keyboard, right above the touch pad buttons. It's possible to replace the memory module without disconnecting the keyboard.
Disconnect the keyboard . Simply grab the blue tag attached to the keyboard connector and pull it up. Now you can remove the keyboard.
So now with removed keyboard you can clean it .
Jan 22, 2013 | Dell Latitude D610 Laptop Computer -...
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
When i type shift + 3 i get " instead of @ what could be the problem
Depends on you keyboard layout, check the settings in start -> settings -> control panel -> regional an language options, go to the 'Languages' tab and click 'Details' and select the correct keyboard layout.
Jan 28, 2011 | HP Compaq 2510p Notebook
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
How do i remove acer aspire 5670 keyboard to replace cd/dvd unit
Hi there.
Push the screen back
Lift up the keyboard bezel using a small flat-head screwdriver.
Continue removing the bezel with your fingers.
Lift up and remove the keyboard bezel.
Remove two screws securing the keyboard.
Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Remove the keyboard.
Good luck and thanks for choosing FixYa!!
Sep 04, 2009 | Acer 9J.N5982.C5D - Aspire 5670 Series...
How to turn on my wireless laptop (hp)?
Open start menu, settings, network settings and open this. Click on the icon for wireless and enable it, then the wireless should work. If you don't use wireless disable it and click on the other icon and enable it unstead.
Jul 06, 2009 | HP Computers & Internet
How many RAM slots in HP 2510P notebook?
There are two slots, one is user accessable on the bottom of the machine and the other is located underneath the keyboard
Dec 16, 2008 | HP Compaq 2510p Notebook PC
Keyborad problem
hi!
All of You
i Read it your problems
quatition :----how i can remove keyboard i didnt find keyboard screw on the keyboard
plz help me
solution:-----if you not find out skrew you just Remove The Battery see the skrew
and just open it
Nov 10, 2008 | HP Pavilion dv4000 Notebook
Keyboard replacement
Manual can be found here. Parts 1-3 must be downloaded before opening.
Directions from the manual for removing the keyboard:
(User-Replaceable)
Required Equipment
• #1 Phillips screwdriver.
Removal Procedure
Unplug the AC adapter, if present, and remove the battery.
Remove the keyboard cover (page 2-12).
Remove the four M2.5×4.0 mm screws that secure the keyboard to the top case.
Lift up on the keyboard at the switchboard PCA end and then pull it toward the display assembly to release the tabs from the top case.
Turn the keyboard over and disconnect the motherboard cable.
Reassembly Notes
Caution
Do not excessively bend or fold the keyboard cable. Excessive flexing can damage the keyboard cable connectors.
• Lay the keyboard face down on the top case, forward of its normal position, then reconnect the keyboard cable.
• Slide the metal tabs on the bottom of the keyboard into their slots in the top case, then lower the keyboard into place.
Apr 01, 2008 | HP Compaq Business Notebook NX9010
HP Compaq 2510p Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
