Toyotomi air conditioner E5 error - Heating & Cooling
5 Suggested Answers
hemantraj
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 1796 Answers
SOURCE: Freon R-22
Hi!!
I would not worry about the R-22 gas part. First, you do not have to put gas in an A/C unless there is a leak. The A/C gas is not like propane that you have to keep refilling because it gets used up. A/C gas circulates in a closed system and years can pass before you may even need some. Take for example the R-12, it was fhased out in 1994 and it is still available (for technicians only) 16 yrs. later.
So if you like the unit and the $$, get it.
Don't forget to rate this post. Good Luck!!
Posted on May 23, 2010
Testimonial: "Thanks for the advise. You made a reasonable point about not needing to replace the refrigerant for years."
SOURCE: Samsung AQV12VBA error cod displayed E5 54
Check the freon...
Posted on Jun 09, 2010
How do I recharge freon on a toyotomi TID 1800 unit?
You can't. You have to be licensed to use and dispense refrigerant gasses. 'Freon' went out years ago. Look in Yellow Pages for someone local.
Oct 10, 2016 | Toyotomi TID-1800 Air Conditioner
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
My 1800 will put out ac and then will go off
Check an error code displayed?
If unit stops immediately after you switch on, fan motor mechanism locked. Check motor and PCB.
If unit stops after few seconds, check coil and room air sensor and replace if it's defective.Helpful?
Jan 19, 2011 | Toyotomi TID-1800 Air Conditioner
Btu of Dimplex Dac 3400/Toyotomi TID-1200 please
It is a 3400BTU unit--Checked from my own unit.
Cheers,
Tony
Sep 09, 2010 | Toyotomi TID-1200 Air Conditioner
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR CONDITIONER - MODEL CS-E28HKR ?
F-96. Over heating protection. to solve it-------Check for • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor)
Nov 21, 2009 | Toyotomi TID-1800HP Air Conditioner
Heatcool toyo ta-09chs
hi friend,
go to website
www.retrevo.com/samples/Toyotomi-manuals.html
i think this may solve ur problem
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Smells like gas
anytime you smell gas turn off the gas at source quickly.
Dec 22, 2008 | Toyotomi TID-1800HP Air Conditioner
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
