Black smoke from washing machine - Washing Machines
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Why is my washing machine smelling like burnt rubber and filling up with black smoke on the spin cycle
I'm having trouble posting my answer. It keeps telling me to use English characters. I don't see any other types so I'm going to try in pieces. Also I did upload the LG service manual for this washer but they are reviewing it first.
Aug 18, 2014 | LG WM1814CW Front Load Washer
Washer squealed, gave off black smoke in spin cycle
For sure change the belt. Clean the pulleys with a solvent to remove anything oily or like melted belt. The machine probably was overloaded. If it's a front loader, check the bearings.
Nov 24, 2013 | Washing Machines
Blown fuse but appliance still works
There may be a short AROUND the fuse. Kinda rare but it does happen.
Nov 22, 2017 | Beko Wm & Wma Models Washing Machine Motor...
CAN BLACK SMOKE MESS UR P MY F-350 MOTOR IF I KEEP DRIVING IT
yes, black smoke means the engine is over fueling and will cause cylinder wash and eventually scuff a cylinder. (cylinder wash is where the excess fuel "washes" the cylinder of it's oil for lubrication and leaves just fuel which does to lubricate very well.
Jul 17, 2009 | 2004 Ford F350
Washer started smoking
You might have overloaded the machine and the belt will smoke;the machine will still work,the items still might be wet due to the fact the machine couldn't spin fast enough.
May 04, 2009 | Kenmore 24032\24036 Top Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Smoke from washing machine
CHANCES ARE ITS THE MOTOR START MACHINE RUN IT IF POSSIBLE FOR A FEW MINUTES TILT MACHINE BACK AND FEEL THE MOTOR IF IT IS HOT YOU NEED TO REPLACE IT (THE MOTOR)
Dec 11, 2007 | Washing Machines
Um..... not quite sure....
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Jun 20, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
