Question about Karcher Garden
T200 patio cleaner won't spin
The rotating head no longer spins, but can be turned by hand (although very stiff). Cleaned thoroughly, lubricated (dismantled as much as possible) ... at a loss as to what to try next.
brector3
  • 1625 Answers
SOURCE: My razor blade heads no longer rotate but when
It sounds like your heads are damaged and need replaced. You can not repair theheads if damaged. You will find replacements for Arcitec shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on May 08, 2010
  • 500 Answers
SOURCE: my washer will not spin,
Hi mwilczewsk,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Posted on Jul 18, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Tally Girl
  • 1133 Answers
SOURCE: My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Posted on Aug 02, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: brush inside main head doesn't spin, and stops
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 12, 2011
    Chain will spin when I put clutch and bar back together start it up chain spins then stops and clutch gets red hot?
    or a to thick chain or the chain was not cleaned after use before a long time The chain may be stiff with tree resin, you have the chain anyway can rotate by hand when the machine is not on the safety brake
    Jan 30, 2016 | Garden
    Pedals are locked won't spin foward but will spin backward
    see the following steps, and fix it. God bless you
    Pedal Arms
    Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
    Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
    Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
    Nov 28, 2012 | Nautilus R514 Recumbent Bike
    TB70ss clutch
    Check to see if there is any material collected around the base of the head, around the tube that provides the energy to spin. It may cause the power to be diminished a great deal, so that must be cleaned away thoroughly. Check to see if you can spin the head freely by your hand, without the motor being on. If not, it may need lubrication down the indide of the power shaft. A light grease would do that, or even a heavy oil poured down the shaft, but not too much.
    Sep 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
    Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
    Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
    Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Hi,dyson dc25 overdrive,my brusher's wont go round,i have cleaned the brusher's and filter,loads of suction.the belt is intact and the roller move's feely by hand,could it be the switch
    Hi Stephen,
    I'm sorry to hear you've had difficulty with your DC25 Overdrive. If the brush bar won't rotate, and you've already checked the cleaner head is free of obstructions, it's likely it just needs resetting.
    You might like to take a look at the video below to make sure everything is correct with the machine. Once you've done this, if you turn the machine on, recline it into the vacuuming position, then press the silver brush control switch twice, this should reset the brush bar.
    If you'd like any further assistance or advice, please give our Helpline a call on 0800 298 0298. Just to let you know, calls are free from UK landlines, and the Helpline is available from 7am-10pm, 7 days a week.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com/
    Aug 01, 2012 | Vacuums
    Brushes don't spin
    I'm sorry to hear you're having difficulty with the motorised brush head on your DC31 Animal. If the head won't seem to work correctly after you've checked for any obstructions, I'd encourage you to get in touch with us directly as we'd appreciate the opportunity to provide further assistance.
    You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call, as one of our advisors may be able to resolve the issue with some troubleshooting over the phone.
    Best wishes,
    Jack
    May 11, 2012 | Dyson DC31 Animal Bagless Handheld...
    Shark SV736R motorized brush won't rotate
    The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
    Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
    The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
    The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
    Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
    Brush will not spin any longer
    If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
    Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
    Garden Logo
    1,454 people viewed this question
    Top Karcher Garden Experts
    John Trevino
    Harold Baxter
    Level 1 Expert
    Are you a Karcher Garden Expert? Answer questions, earn points and help others
