Question about HP LaserJet 3050 All-In-One Printer
"no answer" i try to send out a fax and the phone line is good and working but i try to send out a fax and it says "no answer" .. PLEASE HELP!!!1
    Genius:
  • 2,120 Answers
Call the number from a regular phone line and listen for fax tones. No fax tones....it's not a fax machine, or the recipient has their fax machine set to MANUAL RECEIVE.
Posted on Jan 23, 2009
My fax will not send. the report says fax sent and the result is no answer
Sounds rather conflicted...any way, first step "send" a fax to a phone that rings (cell phone, phone near the fax). Make sure that the phone you are calling rings, if not plug a phone in to the fax line and make sure you have a dial tone. If you do try to change the phone line on the fax and repeat. Basicly this step is to ensure the fax is dialing out.
Next, dial the number you are faxing to with your cell phone or another phone. Does the fax machine at the other end answer (squaking noises). If not are you dialing the right number. If the fax machine at the other end does pick up, hang up and wait a few mins (so the line will clear) and try to send your fax again.
Try sending a test fax to a known good (have sent faxes to the number before with success) fax. If this works, its a communication hand shake error. You may need to power cycle both fax machines.
Last Test, plug a different fax machine in were this one is. Using the same phone line and such try to fax again. If this is the only thing that works, the fax machine may have a bad modem.
If further information on testing the modem on the HP fax is needed let me know.
I hope one of these step gives you the help and information you are looking for.
Jul 22, 2011 | HP PSC 950 All-In-One InkJet Printer
My company lexmark X642e all in one machine was faxing fine. I unplugged the fax line and plugged into another fax outlet plug and it would not work so I plugged back into the original fax line outlet and...
Make sure you plugged it back into the right port on the printer itself. The one I have actually has two different phone line plug-in ports - one is for the FAX line that connects to the wall. The other is so you can attach a separte phone as an extention to talk on. Good luck. Also, after it is plugged back into the wall, did you power down, wait 30 seconds and then power back on? Sometimes these things need to recognize at start up whether or not they are connected to other devices, etc. Good luck.
Jun 17, 2011 | Lexmark X642e All-In-One Laser Printer
WE CAN SEND A FAX BUT CANNOT RECIEVE A FAX THE PHONE LINE IS CONNECTED TO LINE AND NOT PHONE PLEASE HELP
try setting the answer mode to auto answer. It may be in manual answer mode. Also try calling your fax number and see if it rings.
Feb 19, 2011 | Canon FAXPHONE L80 Laser
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Dec 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Busy/No Response
Using a cell phone, call your fax machine to see if the fax answers. If it does answer, then hang up the cell phone and fax. Next, using the HOOK button on your fax, call your cell phone . The cell phone should ring and answer the phone call from the fax. If you do not get a connection between the fax and cell, try these: Check that the phone line to the fax is plugged into the LINE jack on the fax, NOT THE PHONE jack. The PHONE jack on the fax is to plug in a TELEPHONE ONLY. If the fax phone line is OK, go into your fax machines' RECEIVE and SEND settings and make sure they are set up properly (pulse or tone dialing, overseas mode, etc.) Print out the HELP LIST as follows: Press MENU button, then 5 on keyboard, then 1 on keyboard. Go through all the settings on the HELP LIST that apply to your problem. (Send and Receive modes, Ring Delay, Receive Options,etc.) Write down the original settings BEFORE YOU CHANGE ANY OF THEM.
Aug 25, 2008 | Brother MFC 420CN All-In-One InkJet...
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Jan 08, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
HP LaserJet 3050 All-In-One Printer Logo
148 people viewed this question
Ben Johnson
