Take apart a vestax pdx 2000 - Audio Players & Recorders
SOURCE: vestax pdx 2000 mkII
you should check the fuse on the other turntable to get the correct size, if it persists in blowing you should realy send it back because if you were to use a larger fuse you run the risk of blowing something in the deck, i know its not a great help but its all i can offer
Posted on Dec 13, 2008
  • 104 Answers
SOURCE: pdx 2000 stylus calibration
Hi Misskit , i have a Dual turntable straight arm [Dual is the brand ] maybe you could visit their website and see if there is something similar to yours that you could get some specs from , i think they are still in business they are a German turntable manufacturer . happy spinning
Posted on May 26, 2009
  • 5 Answers
SOURCE: vestax pdx 2000 motor problem
This is a really common fault with this model of TT. I've just repaired a pair of them with the same problem.
You need to remove the bottom cover of the deck then take the round cover off the bottom of the motor assembly. Be really careful with that, delicate sensitive stuff inside. Once you remove the screws use a small flat blade screwdriver to lift it free of the rubbery glue that seals and holds it in place.
Once removed, in the centre of that cover is a small black rubber cirlce about 6mm in diameter that the shaft of the motor rotates on. The problem causing all of that erratic platter movement is with this small black circle.
The solution I found was to use double sided tape to hold this part in place. This serves two purposes. First, to stop the part from moving off its required location, Secondly, to raise the part up slightly from the bracket that it sits on. Layer the double sided tape up so its the around the same thickness as the small black rubber circle. Then place the black cirlcle into its original location bedding it firmly into the tape.
A tiny small dolop of grease on the end of the motor shaft. Replace the motor and bottom covers. Bingo! The decks a-go-go!
Happy mixing!
Posted on Jan 12, 2010
  • 5 Answers
SOURCE: I have problem with tonearm on my vestax pdx 2000
I'd be checking the weight and height settings of the tonearm. Heres a link to the manual for the deck. There's instructions in there about how to setup up the tonearm properly. Don't be afraid to experiment with it. Just remember, too much weight will wear out your vinyl really quickly. Not enough weight will sound like **** and skip easily. Have fun!
http://www.vestax.com/v/info/support/pdf_players_manuals/VOM-PDX-2000E.pdf
SOURCE: Vestax PDX 2000 motor going crazy problem
hey, it will work with the tape solution but you gotta pay attention to the light metallic circle which is used by the light sensor (the small black one with cables on it) to estimate motor movement - first time i opened it and did the tape thing to the black rubber circle i eventually touched the light metallic circle and i think that caused it not working for me too
the light metallic circle must be totally clean and plain, do your best, but be sensible
Posted on Dec 20, 2010
Vestax pdx 2000s. Where can I get tonearm counterweights? I cannot find any online many thanks!!
I recommend you search for just tonearm counterweights. Rather than your make of deck. You will then have to compare them to see if it will fit your arm. Amazon do have them for different makes. Vestax might be just a name given to a shop brand, the deck itself being made by a more well known company.
May 31, 2015 | Vestax Audio Players & Recorders
Clibrate pitch Vestax PDX d3S
It's a variable , since it's depended on more parts, but just clean it first and gently turn it until the platter moves correct,assuming you
mean to correct the variable resistor(potmeter) . If the value was everywhere the same, then you don't need a variable resistor:)
Jun 19, 2013 | Vestax Handy Trax Turntable
Hi,my vestax 2300 platter has a slight wobble.i removed the platter and it seems 2 b the motor,can u help?
sliight wobble is normal but if its something you notice i suggest sending it to them to fix it
Apr 28, 2011 | Vestax PDX-2300 Turntable
Does the platter of the vestax PDX-2300 mk 2 fits on the vestax PDX-2300 mk 1?
Hi ezradf ,
i am afraid no it will not fit, the PDX-2300 mk 1 has a bigger fitting then the Mk 2.
Mar 19, 2011 | Vestax PDX-2300 Turntable
Hi, have been given a vestax pdx 2300 turntable and the motor is acting crazy, do i replace motor or is it an internal roblem?
Is there a speed control switch? UNPLUG and try spraying contact cleaner into the speed control. IF that doesn't solve it, then back to the manufacturer.
Jan 11, 2010 | Vestax PDX-2300 Turntable
I have problem with tonearm on my vestax pdx 2000 turntable , no connection with needle , but when I make contacts of the needle wet it sometimes help a bit , but I should do it always to make it work. ...
Dec 15, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Pdx 2000 stylus calibration
May 24, 2009 | Vestax Pdx2000 Direct Drive Turntable...
I carnt remove the turntable platter can anyone help
The platter needs a drop of oil as the platter and motor shaft is a machined fit, Via brass upside down v as the platter will be reversed ie: a A WITH NO LINE . You can place two plastic wedge shaped blocks ,one on each side of the platter with even pressure and work up.
May 09, 2009 | Vestax PDX-A1MKII Turntable
52 people viewed this question
 Grubhead
Grubhead
