I have this toshiba satellite laptop that I need to activate windows on but I can't get on the Internet it says I can put a proxy server address and a port in to establish Internet connection HELP
To activate Windows you can call the 800 number that is given during the activation process. Or find the number online. Or call Toshiba.
You probably do not need to use a proxy server, so bypass this or change your settings in Internet Explorer.
Posted on Jan 12, 2013
  • 115 Answers
SOURCE: wireless connection for toshiba satellite A135-S4527 laptop
Hi, there are few steps to allow the wireless network to get connected to the internet.follow these steps
  1. Verify that the Wireless hardware is working (Right click the My computer icon then goto properties then hardware tab and device manager.see the network adpater is corrctly installed.
  2. Then you can check the ip address in the ethernet properties.
  3. Then check the DNS server is connected
if it is not working , i have one web site here you can see the settings and devices to connect.
http://www1.umn.edu/adcs/network/wirelessxp.html
try it and inform to fixya.com
Posted on Jun 03, 2008
Rick60639
  • 29 Answers
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Posted on Dec 01, 2008
shakeelm
  • 224 Answers
SOURCE: Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Posted on Mar 04, 2009
jonb3838
  • 237 Answers
SOURCE: Toshiba Satellite Laptop 1115-S103 trouble shoot VGA & projector
it should be f5 if not then look for an icon that has a computer screen on it
Posted on Apr 08, 2009
SOURCE: Toshiba Satellite L355D wont connect to the wireless internet
i am having the same problem and its not software related as i have my laptop dual booting with sabayon 5.0 and im getting the same result in that OS so this tells me that the hardware is failing
if your problem is the same as mine have you exposed your computer to cold or humid atmosphere?
mine sat in my trunk for a week this newyears
Posted on Jan 09, 2010
Internet access
Windows or Mac Os ?
Windows go to control panel then go to network conections open this contain and go to ip config and change all here propieties put all ips default and is all coment please
Apr 21, 2014 | Gateway Computers & Internet
Proxy server
Can you use automatic, instead of using proxy? Do you have to use proxy?
Mar 07, 2014 | Toshiba Satellite Laptop L655S5150
I can no longer access mail2web.com on my laptop. I get a message that says "windows could not automatically detect this network's proxy settings".
may be a proxy server problem if your using windows then By using your Windows VPS as a proxy server you will get the best performance and have the most control over the proxy. Setting up your Windows VPS to work as a proxy server is simple, all you need to do is install proxy server software, such as CCProxy, and add a rule to your firewall.
Feb 16, 2014 | Toshiba Satellite Computers & Internet
I can't get my LAN settings to automatically detect settings, box will not check.
Reset your proxy settings
Proxy servers, or proxies, act as intermediary servers between a Web browser and the Internet. According to Microsoft's website, proxies are mainly used by networks in companies to enhance the security and speed of their network connection.
Proxy servers can also be used to log Internet usage, mask the network address of a server or to apply global restrictions to a network.
Internet Explorer is set to automatically detect proxy servers by default.
You can reset the Internet Explorer proxy settings to their default settings from the "Internet Options" configuration.
I have found the easiest way to do this is to add the menu to the top of a webpage.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on tools option then from the drop down list Internet Options
Select the "Connections" tab, and click the "LAN Settings" button.
Delete the proxy server address and port from the "Proxy Server" settings and clear the "Use a proxy server for your LAN" check box.
Clear the check box beside the "Automatically detect settings" and "Use automatic configuration script" options in the "Automatic Configuration" section of the "LAN Settings" dialog window. Click "OK."
Click "Apply" and then "OK" to save these changes and close the "Internet Options" dialog window.
Close all Internet Explorer browser windows for these changes to take effect.
http://windows.microsoft.com/en-US/windows-vista/Change-proxy-settings-in-Internet-Explorer
Sep 12, 2013 | Computers & Internet
What is proxy server address for asus pc 900
Click the "Tools" menu and select "Internet Options" to open the browser properties.
Click the "Connections" tab and select "Settings" to open the proxy server configuration.
View the section labeled "Proxy Server." This contains the Internet protocol and port address for your proxy server.
For Firefox
Click the "Firefox" menu, select "Options" and choose "Options" again from the menu that slides out
Click the "Advanced" tab and select "Network" tab. Click "Settings" to open your proxy server configurations.
View the section labeled "Manual Proxy Configurations." This lists the IP and port addresses for your proxy server
hope this helps
Sep 22, 2012 | ASUS Eee 2G Surf Notebook
Globe access point
APN: Go to MENU, SERVICES, DATA ACCOUNTS, GPRS, create NEW SETTINGS.1. if your globe sim card is not yet activated for inet, then configure it manually.. go to connectivity then go to access points, make a new one and name it Globe inet..then on the APN put this "http.globe.com.ph" without the "
2. then after that, go to internet profiles, make a new profile and name it globe inet.. name it Globe inet. then choose to use a proxy.. then enter this proxy address "203.177.91.131".. and then it the proxy server port, put "80".. then on the access point choose Globe inet..
3. now you need to make another internet profile.. so make a new one. name it "proxy".. then choose to use proxy, and then enter this proxy "195.189.142.132" then on the proxy server port put "80"..then on the access point put Globe inet..
4. ok now your done configuring your globe inet settings,. next step is to go to games and apps, then choose settings, then choose profiles, and add profile.. name the profile "proxy". then on the internet profile choose "proxy" then save it and activate it..
Feb 14, 2012 | LG Cell Phones
My wireless is working perfectly. But when i click on the Internet Explorer Icon to go on line it says " Internet Explorer Cannot display webpage". So I clicked on "Diagnose Connection Problems". The box...
to: Start > Control Panel > Internet Options > Connections > LAN Settings. Uncheck the "Use a proxy server for you LAN (These settings will not apply to dial-up or VPN connections). !
Sep 29, 2010 | Compaq Computers & Internet
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
How to connect to internet using LAN
Check that you have entered DNS Server Ip and Router IP address as your default Gateway in network card ip settings...
run command:--Start-->Run--->Type.....Cmd
Enter----Type...Ipconfig/all---will show you ip details
Check Router Config(if uoi manage)that NAT Proxy configured on that.....
Oct 02, 2009 | Toshiba Satellite 1715XCDS...
Cannot access server dns error occuring with internet explorer 6.0
make sure your dns setting is correct follow this :In the Windows Control Panel, >go to Network Connections.> Open 'Local
Area Connection' and select 'properties'.
Doubleclick on Internet Protocol (TCP/IP)
check or Select 'Use the following DNS servers'. Put the correct dns address in the primary
address window. Leave the alternate blank. Close all the Windows. Try
browsing again
Sep 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
