Question about HP Compaq d530 CMT PC Desktop
Cannot empty C:\Windows\system32\config\systemprofile\Local Settings\Temp file it keeps coming up disc is full or write protected how do i clear this?
Every time i go on the internet it this file gets larger and larger
  • HP Master
  • 7,627 Answers
Use CCLEANER freeware at : http://www.filehippo.com/download_ccleaner/ this will clean the junk from your machine. ALSO , Use these tips to Clean up Win XP: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer In the Disk Clean section, Open Disk Clean, More Options, System Restore, Clean all but recent restore. Reboot. Use this procedure to flush the DNS: http://technet.microsoft.com/en-us/library/cc781949(v=ws.10).aspx
Posted on Jan 12, 2013
5 Suggested Answers
  • 230 Answers
SOURCE: computer will not boot
1. Reboot with windows cd in the drive
2. When asked to press any key to go into windows setup do so.
3. Wait for the menu to come up, it'll take a while to load drivers, you just have to be patient.
4. Press R at the menu for recovery console.
5. It will ask for your administrator password, when it does press enter or type it if there is one.
6. At the prompt type chkdsk /r and press enter
7. Wait.... Could take an hour.
8. Type exit and your done.
This is normaly caused by a corrupt filesystem and that check disk should sort it.
Posted on May 08, 2009
taran_2005
  • 10515 Answers
SOURCE: windows will not start because
The above message refers to Window Crash.
Either you need to load all the files that have been deleted or affected or You might need to reinstall windows.
I would advise you to reinstall windows. Make sure you create a back up of the same so that you will not lose saved data, if any.
Any further help, let me know.
Thanks for using Fixya.
Posted on May 29, 2009
cq92
  • 184 Answers
SOURCE: my computer is missing a file
Reinstall windows.
Sometimes using the "repair" option first on a reinstall will fix it.
Basically what is missing is the system configuration information.
Another option is to remove the drive and place it into a working machine and then scan the drive with a file recovery utility to find the missing files and restore them, that depends on how technical you are or familiar with file recovery procedures.
Posted on Aug 30, 2009
  • 173 Answers
SOURCE: windows could not start because
here is an article from Microsoft on how to recover from this but the bad thing is you will need a CD with your operating system on it. if you are running windows xp you can borrow one from a friend and it will work. here is the link anyway and good luck.
http://support.microsoft.com/kb/307545
Posted on Nov 01, 2009
Windows\systems32\config\system file is missing or corrupt
You can order a new set of disks from the manufacturer or pull out the had drive and plug it into another PC or buy an external hard drive dock . Newegg has them for around $20
Mar 09, 2014 | Insignia Computers & Internet
Fix acer aspire one wireless
Restart the computer, and keep pecking on the F8 key at the top of the keyboard. Cursor down to Last known working configuration, System Repair, or enter Safe Mode. In Safe Mode you'll be asked if you want to use System Restore. Use Safe Mode to select a date before the problem first arose.
Dec 09, 2013 | Computers & Internet
Hi guys, my notebook 0xc00000e9 this problem and how I want to save or return all my program really work? I need to go back but I do not want to format? need to save my back as folders? I hope you...
This error indicates a corrupt registry. Luckily, when Windows is installed, a pristine copy of the registry hives is also installed and it remains untouched...replacing your corrupt registry hives with these ones will allow you to boot your operating system again. You may have to reinstall a few programs and drivers but all of your data will remain intact and you really won't lose anything. I will describe the process to you. I will also include instructions on how to back up the current registry in case you want to go back to it for any reason.
First you will need to locate the Windows install disc. If you don't have one you can borrow one as you will not need a key to perform the steps.
Put in the disc and perform the steps necessary to get your computer to boot to it.
Once you are the "Welcome to Setup" screen, press R to go into the Recovery Console.
Enter the administrator password when prompted
Tell the program what installation of Windows you would like to recover.
Now for the commands
md tmp (this creates a directory labeled tmp)
These 5 commands will make a copy of your current registry hives and back them up to the tmp directory. Type these in first. ENSURE you back them all up.
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
These 5 commands will delete the current, corrupt registry hives.
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
These 5 commands will copy the pristine, uncorrupted hives into your system.
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
Once you have entered your last command type exit to leave the recovery console and your computer should restart.
If you want to put the old registry back for any reason, simply follow the same steps but instead delete the current registry and replace it with the files that you placed in the tmp directory. Ensure that you remove the .bak extension from the file when you copy them over.
Really, other than this, the only other known working option is to reformat your computer.
Hope this helps.
Jun 27, 2011 | Computers & Internet
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Hp paviliondv2050us wont start
To complete part one, follow these steps:
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
You may need to go into your BIOS and change the settings so the PC boots from the CD, not from the HDD. It should then start up and allow you to reinstall or repair.
Nov 08, 2007 | Computers & Internet
HP Compaq d530 CMT PC Desktop Logo
147 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
