I have problem with water flooding from machine I have put unblocker cleaner down waste water down pipe so must be filter on machine on previous machine they have a filter on the front you can clean
    Problem Solver:
  • 9 Answers
Hi
Not sure about your machine, we have a front loader. I guess you are talking about the same thing.
There is a filter in the front bottom, to collect pins, coins etc.
If this is not replaced correctly it will leak.
To service this filter unscrew it, clean it and the objects from it, then rescrew it back into the machine.
To test, without running the machine, simply pour some water into the detergent tray at the top. If water comes out the filter - it is not sealed. simply remove and try again.
Hope this solves the problem
Posted on Jan 12, 2013
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
  • 262 Answers
SOURCE: washing machine
there is a tool that hooks to you garden hose that goes in your pipe and expands then blows water down the drain to blow out stoppage it work great you can get it at your local hardware store
Posted on Dec 20, 2007
SOURCE: miele W830
I have exactly the same problem - what was the answer ?
Posted on Apr 05, 2008
barkencoa
  • 3463 Answers
SOURCE: indesit wil 133
The filter is located behind a removable plastic panel on the bottom front of the m/c.
Posted on Dec 02, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Posted on Aug 28, 2009
Water fills up in the tub but won't drain from the washer.
Filter may be blocked. Be careful taking it out, you will get flooded. Make sure you have something to collect the water as it rushes out. Also check the main drain isn't blocked. If you know how, unplug the rubber waste pipe at the back of machine (not from the bottom of machine but from where it connects to main drain) and see if the machine empties by running spin cycle. If water comes out of pipe then it's the main drain....if not it's either the pump or filter.
Nov 13, 2016 | Washing Machines
Tip
How to unblock a washing machine pump
Below is a step by step guide on how to unblock the filter on a washing machine:
1: unplug the appliance
2: lower the waste pipe to the floor to siphon out all the water
3: Locate the filter (normally on the bottom right hand side behind a flap)
4: Unscrew the filter anti-clockwise and pull out
5: Remove any debris from the filter
6: Spin the impeller with your finger to ensure it moves freely
7: Reinsert and tighten filter
8: Plug in appliance and select a wash cycle. Do not put on a rinse, spin or pump out only cycle as this will not reset the pressure switch to empty (only applies to certain models)
on Apr 11, 2014 | Washing Machines
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Wixl123 does not drain after washing ?
Drainage problems can be caused by:
a) Blocked Filter chamber
b) Blocked Sump
c) Blocked Drain Pipe
d) Blocked waste pipe
e) Failed Pump
You can check the sump and drain pipe are not blocked by disconnecting the drain pipe from the undersink trap or waste pipe and lowering to a bowl on the floor. The water should drain out into this bowl under gravity if there are no blockages. Bear in mind if you have disconnected the drain pipe from an undersink pipe if youpour the drained water down the sink it will flood into your undersink cupboard. If this drains then you check the waste pipe or undersink trap is clear. You should also check the filter chamber if it is accessible on your washing machine (not all are). I would recommend you unplug the machine or take the fuse out of the switched socket before doing this. Drain the drum as above before doing this or you will get a gush of water coming out. You will usually have to remove a cover from the bottom of your machine to get to the filter chamber and twist it ant-clockwise to unscrew it. Check for any coins buttons etc trapped in there. If there is nothing there check the impeller will turn relatively easily by hand. If you still can't find the problem you might have a faield pump and I would recommend contacting an enginee
Apr 03, 2011 | Indesit W 123 Front Load Washer
Is there a lint filter I can clean in the Whirlpool Duet? I have water come up out of the drain pipe when it empties. I already put drain cleaner down the pipe but water still comes out sometimes. is there...
its your drain pipe thats blocked up,, i take it its the one that the washer is pushed into and go's out the wall to the drain that the water is coming back up from,,,in all sope powders there mostly made from a "clay base" so the out let pipe is blocked with "clay wast" push a cleaning rod down the outlet on the wall,,,down to the drain to clear it out its not likley to be the washer thats blocked up,
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Haier front loader 1400 spin
check to see that pump is not blocked stopping water getting away quick enough
Mar 16, 2008 | Haier XQ8M22-C PORTABLE TOP LOAD WASHER
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
