Question about Plumbing
Removing a stove pipe through the roof
I bought a house that I believe used a wood stove to heat the house, and they left the pipe in the roof. It has started to leak now when it rains, so I would like to remove it. how do I get it out? Can you torch it off? Or cut it off? I have no idea.
  • 10,865 Answers
I would begin by going up on the roof to see what the situation is because you are going to have to remove the stove pipe and repair the roof to assure no leaks. Usually the only thing holding the pipe is roof cement through a rubber boot. Use a razor blade knife to cut through the tar, then remove the boot by pulling the roofing nails that hold it in place. After that, patch the roof and reshingle. If this is more than you care to do yourself you will have to hire it done. good luck
Posted on Jan 23, 2009
Just bought a house with a Gibraltar SCR stove in it. I want to use this thing, but have never owned a stove and don't know how. What fuel? How to set the fuel in the stove, etc. Can you help?
Gibraltar makes coal, pellet and wood stoves. Stoves that burn wood pellets have a hopper and feeder auger that feeds pellets into the burning chamber. They also require electricity to work. From what I read online you should be able to burn wood in the stove but I believe the coal stoves have a smaller burning chamber.
Nov 28, 2017 | Heating & Cooling
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
Why does my blazeking wood burning stove get creasote in the fire box and how do i get it out?
Hi Darlene,
Creosote consists of combustion byproducts,[smoke] that gradually builds up in the stove & chimney.MOISTURE in the wood,and slow burning greatly increase build-up. 1/4 '' of creosote is considered a hazard. Consult a professional chimney sweep,then burn only 'seasoned' dry hardwood,and when you start or re-kindle the fire,burn it hot enough to thoroughly heat the flue; this will draw the smoke up the chimney faster,decreasing the time build-up can occur. Stay Warm!
Nov 25, 2014 | Home
I bought a house with a wood burning stove but I don't know how to operate it
First make sure everything is clean,from the chimney to the stove.insure all metal flues are tight from stove to chimney. Open damper on top of stove(some are in metal pipes). Open your draft vents, usually on clean out door at bottom. Depending on chimney draft you may need to open clean out door to get it started. Load your kindling and get it started. Add bigger wood as it catches. Turn down venting and drafting as the fire roars. Just don't shut draft before vents. You'll get used to balancing draft and vent as you go. I hope this helps
Nov 19, 2014 | Home
Poor draft on savannah woodstove
Drolets are a real pain at times. Don't buy their pellet stove. Check your stove pipe to insure its clean and not blocked. This includes spark arrestor. Is you stove cap 2' higher than anything 10' away from pipe? Refer to install manual. If you are not getting an y back draft issues with smoke inside house you may need to add on a section of trip wall pipe at the top.
Feb 27, 2014 | Drolet Savannah 55,000 BTU Wood Stove,...
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
After installing the pellet stove,the stove seems to 'burn up" the pellets to fast not creating a "coal bed ',no real heat is going in the house.It is a breckwell big E mod. 55'000 btu...
Not sure what is happening but if the pellets are burning too fast that tells me you have to set the air flow while they are burning. Even a wood stove will burn to fast if there is too much air . There should be a setting for the air flow on all stoves and some times it should be almost closed. if it continues i would contact the stove seller and ask them.
Sep 04, 2017 | Heating & Cooling
Offset of verticle stove pipe between stoveand chimney
use single wall pipe in the heated area.
Aug 19, 2008 | Grilling
Plumbing Logo
1,020 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
