Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Kenmore (frigidaire) front load washer shakes
My new washer shakes while spinning. A service man told me to check and make sure the shipping staps had been removed from the back of the washer (inside a panel). I opened the panel, but did not see any strap. Is there something else that ties this thing down during shipping that might not have been loosened or removed? I have the washer on soft tile floor (it's kinda spongy). The service man said this was the best floor to have it on since it absorbs some of the shock. I am thinking about putting a 1/2 inch plywood base under it. Will that make it worse?
    Novelist:
  • 101 Answers
The ply wood will probably make it better. If this is your first front loader then this is all going to be new to you. Front loaders have so much force during the spin cycle and all of that force goes straight to the floor. It will shake like crazy and sound like a plane flying through your house if your floor is not strong. The best thing to do would be to hire someone to come out and go under the house to stabilize the floor under the washer. A simple 2x4 under the washer will do and minimize the shaking. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad that I could help you.
Posted on Jan 22, 2009
Frigidaire fahe4044mwo shakes in spin cycle
Good Morning Friend,
I understand that your Frigidaire washer, model# FAHE4044MW0, is shaking in the spin cycle. First, please check and make sure that your washer is resting firmly on the ground and does not move if you try to shake it. Secondly, make sure that all shipping bolts have been removed when you installed your appliance. Thirdly, make sure the load is not too small. Add a couple of similar items to even out the load. Lastly, make sure that the wash load is distributed evenly. Stop your washer and rearrange the load if you need to. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Washing Machines
Front loader kenmore he2plus rocks the house on spin cycle?
make sure the unit is totally level on all4 corners if this dont cure it make sure there arent any shipping bolts toward the bottom that were supposed to be removed after installing that are still on them they will have a yellow or red tag that will say remove after shipping hope this helps
Feb 25, 2010 | Kenmore HE2 Plus Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Front loader shakes bad, is level, and on a concrete floor
You will have harmonic inbalance about 800 rpm on most front load machines, causing them to shake termporarily as it ramps up on the spin cycle. Be sure to check if the shipping bolts have been removed. This is the most common mistake most people make while installing front load machines. If you don't remove the shipping bolts, it will cause most machines to shake violently and can cause damage.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore elite steam front load washer
take the shipping materail out,,remoce the 4 bolts on back of machine,,the washer should of came with a little wrench...after removing shipping bolts put the 4 white sluggs or vcaps in hole ,,pull bolts with rubber or plastic grommet..onthejob
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine shakes when spinning out
our's did this, it shook horribly. it turns out one (or more) of the shocks had come out and the technician had to come out and replace the shocks.
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Shaking
We have finally resolved our problem thanks to annetipu's note about someone mentioning a rod or pin that had to be removed. On the Frigidaire website, you will find the following:
14. Vibrating sounds. Tumble action washers: Shipping bolts or braces are still in the washer.
Remove 3 shipping bolts, 3 yellow spacers and 3 metal "P" clamps from the back of the washer. Remove the access panel from the front of the unit and remove 2 yellow shipping braces and large Styrofoam shipping block. Replace the access panel.
This solved our problem. Washer is wonderful now!
Sep 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Spin cycle problem
Which machine exactly do you have ?
Aug 31, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
137 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
