Question about Kitchen Ranges
Designair cooker hood CORHD90SS does not work
Control panel should be illuminated blue which its not, but it does display the time, extractor and other symbols, however the extractor does not work either.
SOURCE: Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Posted on Feb 16, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
  • 142 Answers
SOURCE: CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Posted on Jan 27, 2009
SOURCE: Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Posted on Feb 08, 2009
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
Dww061350b
if both fan and light have quit working then you have an electrical supply problem. start with checking for thrown breakers in the breaker panel. if none are tripped then you have a broken wire or a wire no longer making a good connection. try twisting the wire nuts tighter were it wires in above it
Jun 02, 2012 | Kuppersbusch Kitchen Ranges
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
Charcoal filter for cda cooker hood only number i have is TYPE IN1KB1BS Ref INT/CIN installed nov.2005
I had the same problem. No information in the user manual or on the internet about what filter to use. But actually, its not a problem at all because the filter is a universal one! B&Q sell 3 or 4 universal filters, the important thing is to choose the one that has the same diameter and the same central fitting. The one you need is made by Designair and says on the label "suitable for models VH60S, VH60W, IH60SS. It only costs £4.95.
Mar 10, 2010 | CDA PISCES CPP9 Kitchen Hood
Designair 60cm chimney hood chk60ss what gap between cooker and hood ?
If gas cooker you have to get specs.....We usually get the chef of the house to stand in front...Head banging will be a call back we hate...
Oct 27, 2009 | Kitchen Ranges
Jan 26, 2009 | CDA Kitchen Ranges
Its worth $110.00
gtp_jmp
Jan 22, 2009 | Kitchen Ranges
Baumatic cooker hood lights not working
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
212 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
