Question about D-Link DIR-600 Router
How do i change my d-link dir-600 router password
  • 7,627 Answers
  • 104 Answers
SOURCE: cant figureout how to set a password to a d-link router
Hi…I’ll try and lend a hand. There are several ways to set up wireless security on this router. However, I’ll help you set it up using the manual method.
Important note: use a wired (Ethernet) connection to the router to set up wireless security.
There are four main steps:
1) Login to your router.
I’m sure you have done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. For this router, it is http://192.168.0.1
Select ‘Admin’ from the dropdown box, then enter your password IF you have set one – otherwise, just leave the field blank and press return.
You should then see the configuration screen/user interface.
2) Change the router password.
If you HAVEN’T set a password, this is a good place to start. Go to Tools >Admin option. Set and confirm a password for ‘Admin’, and note it down. Also, set and confirm a password for ‘User’. Click ‘save settings’ when finished.
Make sure these passwords are not easy to guess, or a neighbour could log into your router and view/change all your settings.
3) Change the SSID (router name):
Go to Setup > Wireless Settings. You should see an option marked ‘Wireless Network Name’ or SSID. Change this from the default, ‘dlink’, to anything you like –as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘save settings’ when finished.
4) Enable encryption
Still in the 'Wireless Settings' menu option, you should see the ‘Wireless Security Mode’ section. Under the 'Security mode' dropdown you have a number of options for encryption. WPA is safest....I would pick WPA-Personal.
You should see a dropdown box marked WPA Mode – select Auto. Leave Group Key Update Interval at the default of 3600s.
Under Pre-Shared Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappyhOLIdaystoyou8899). It is case sensitive.
Note down the passphrase carefully. You will need this to connect wirelessly. (The WPA shared key may also be called the network key, PSK, pre-shared key or passphrase). Click 'Save settings' when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the WPA shared key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Posted on Dec 23, 2008
  • 33 Answers
SOURCE: D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
Posted on Mar 17, 2009
heuweiler
  • 56 Answers
SOURCE: I need to reset the password for my router D-Link (DIR-300) Router. The default password was blank. But now it does not accept that.
There is a little hole beside the Power Plug.
This is the reset button.
You´ll need a little paper clip to press the button more then 3 seconds.
Then all in the box is resetet.
Posted on May 02, 2009
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
Geekman
  • 32281 Answers
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
Posted on Oct 21, 2009
I can login but I have forgotten my password
If you can login, either your browser has stored the login settings or the DIR-600 still has the default settings. Change them to something more secure!
Here are the default settings for the D-Link DIR-600:
USERNAME admin
PASSWORD (none)
IP ADDRESS 192.168.0.1
Link UK DIR 600 Wireless 150 Home Router
Feb 24, 2014 | D-Link DIR-600 Router
Download installation cd
I guess u got the Solution. If u dint get it, just try this.
Open IE and type in address bar http://192.168.1.1/
DIR-600 Router Default
DIR-600 Default IP:
198.162.0.1
DIR-600 Default Password:(Blank) Means emty.
DIR-600 Default Username:
admin
Dec 18, 2013 | D-Link DIR-600 Router
In need ip address of router, the default user id and the password
The default username and password of the router (DIR-600 is Username: blank and Password: admin. Default IP of the router 192.168.0.1.
Dec 12, 2013 | D-Link DIR-600 Router
Dlink DIR 600 Sify
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
You should be able to configure your router using the wizards. Login is ADMIN and Password is blank unless it was changed by the user.
Feb 18, 2013 | D-Link DIR-600 Router
Lost user name and password. I have reset my router due to someone else's using the IP address of my router.
Username    admin
Password    [none]
Default IP address   192.168.0.1
Per this page:  http://pcsupport.about.com/od/d-link-default-passwords/a/dir-600-default-password.htm
Aug 15, 2011 | D-Link DIR-600 Router
How to change password for dir-600?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
Step 3: Click the Tools tab at the top, then change the admin password and click on Save settings.
May 07, 2011 | D-Link DIR-600 Router
Somebody cn tell D-Link DIR-600 login password
Welcome to FixYa
Dear User,
Default User name :Admin
Password : admin
Your Product manual also Here..Dont forget to RATE..
Thanks for Connecting FixYa...
Aug 20, 2010 | D-Link DIR-600 Router
How can i change the password of my D-link DIR-635 router
To change any settings on the router, you will need to access the router set up.
Do you have any computer connected to the router with the cable?
If not then you will need connect the computer to the router.
open the setup page and change the settings.
Click Here for step by step instruction
Dec 05, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link DIR-600 Router Logo
90 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
