Question about Cameras
My canon rebel t3i won't turn on after I charged the batteries and this light kept turning on but now the camera won't even turn on .
    New Friend:
    Problem Solver:
  • 9 Answers
First try a different battery in your camera.
second try your batteries in someone elses canon (same model)
third go to some one that can check the battery.
Has the camera got wet at all? if so then ther might be internal damage and need to be serviced
Posted on Jan 12, 2013
Canon rebel T3i does not turn on!!
The camera definitely either needs repair or replacement. If it becomes warm to the touch, turn it off immediately and remove the battery, as this could cause a fire.
Apr 17, 2017 | Canon Cameras
Canon eos 600d, takes a picture on turning on and freezes. When I turn off and on again, it takes a picture again and freezes. Cannot access menu or any other button. how do I resolve this issue?
Camera electronics has developed a mind of its won and has gone crazy. You need to have it fixed or replaced whichever is cheaper.
Make sure the battery is good since many newer electronics operate erratically when the battery condition is not up to par.
Jun 13, 2016 | Canon EOS 600D Rebel T3i Digital Camera
How to fix err20 for Canon Rebel T3i?
Error code 20 refers to a detected mechanical problem
Error code 30 refers to a detected shutter problem
-Turn the power switch to < ON > to turn on the power.
-Remove and re-install the battery.
-Use a Canon lens.
-If the instructions above do not solve the problem you may need contact your nearest Canon Service Center.
Aug 03, 2014 | Canon Cameras
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
My 600D will not turn on however, I can hear beeps when I push the buttons in my cam. How can I fix this?
Make sure with voltage tester battery is fully charged or charge battery for at least 2 hours and reinsert battery and try again. Might have to replace battery and they are cheap on ebay. Rich
Aug 03, 2013 | Canon EOS 600D Rebel T3i Digital Camera
My rebel t3i wont turn on!
unless you put the battery in wrong There is a small diagram on the lid part or in side where the batteries go showing which way the batteries are put in.
May 06, 2013 | Canon PowerShot SD600 Digital Camera
My rebel t3i wont turn on!!!
I just bought a T3i and only used it 2 days of shooting. On third day, it's not turning on and it's 80 degree's. So not cold weather. Batteries are fully charged. When I put batter in and turn the switch on, the red light comes on for only a second and then nothing! Other times the red light won't even come on, period. As I said, I've only had it 3 days and it's dead....
May 06, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Dropped T3i.
Its a DLSR so you can not do any thing at home. You need to visit a canon service center and then they will open the camera and check the circuit board is broken. cracked during dropping or not. And they will repair it.
Aug 07, 2012 | Canon Digital SLR Camera EOS Rebel T3i...
Cameras Logo
580 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
