Question about Air Conditioning and Heat for Acura NSX
Air con leak
Where can i look for leaks in air con for honda nsx they say there are o rings that could leak where can i look for these o rings thanks
  • 60 Answers
Check all the line connections
Posted on Jan 22, 2013
What o ring do I change when I got air coming out the exhust
Need to know the make and model in order to help you!
Mar 02, 2015 | Air Tools & Compressors
Audi TT 225 aircon condenser slight leaking from top.
Hi Andy
As Roger said take it to an AC specialist and have it checked, it will probably need re-gassing. AC gas leaks show up as an oily substance.
Regards Colin
Apr 15, 2014 | 2002 Audi TT
Air con leak
usually the evaporator is right by the blower motor under the dash.although(sorry to say) a/c leaks can be like cancer in a person.Also ask a mechanic if the expansion valve needs to be changed also.be carefull taking it out and you will need orr ring replacements in the joints you take apart .when you are finished you need someone to do a pressure and vacuum the lines before any new coolant is put in,(coolant R12 ect)and ask if the dyer needs to be replaced
Dec 13, 2013 | 2005 Citroen C4 1.4i
2007 Honda Shadow Spirit 750 carburetor overflow
Hi, James and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
SOLVED 2009 Honda Shadow Spirit 750 gas leaking from carb Honda Motorcycle
Fuel leak from
2005 Honda Shadow Spirit 750 Fuel Leak
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C2 Owner Manual
Jul 25, 2012 | 2007 Honda Shadow Spirit 750
Freon doesnt stay in. It keeps dripping out. Dealership quoted over $800. Is there a temp fix to this problem?
nope.depending where it dripping from.if its from a metal air con hose joint then its a $2 o ring seal and some re gassingif its from the compressor then it could also be leaking compressor oil, and if it has been running with no oil then it could be rooted mate.if its leaking from behind the dash then it could be a little tricky.
take it to a recommended auto mechanic with an air con license and he will ascertain the location of the leak.
$800 is what you would expect to pay to install air con to a car that hasn't got it already
Apr 13, 2012 | Air Conditioning and Heat for Acura 3.5RL
Leaking coolant but cant find the leak?checked the radiator and pipes but still cant find it!could it be something to do with the air con unit? only leaks when started and will drain the water out of the...
There is absolutely no way possible that the air con unit is going to cause an engine coolant "leak". The air conditioner can cause the engine to overheat if the fans are not working properly, but you will see coolant coming out of the radiator cap if it is overheating.
To find a coolant leak you just have to look for it while it is leaking. If you can see it dripping out on the ground, then you should be able to follow it up to see where it is coming from. Cracks in the plastic radiator tanks are common in all Honda vehicles. These cracks can have the characteristic of only leaking after reaching a certain temperature. You will probably have to remove the plastic shrouding from under the vehicle to see many of the leaks that can be coming from the front radiator area.
Water pumps can also leak at only certain temperatures. Sometimes they can fool you also because there are channels on the back of the pump that will direct coolant away from the water pump/ timing belt area in the event of a leak. It can look like it is leaking from the side of the engine that is away from the water pump. Again, you have to LOOK to see where it is originating from.
Apr 28, 2011 | 1990 Honda Civic
Hi there. i seem to have a problem with my clutch. i can ride the bike for a while but then the bitting point will get less and less, until it gets to a stage where it wont disenge, the only way i can stop...
In your slave cylinder is a piston o-ring that seals the system. The o-ring sits in a groove. In the groove underneath the o-ring is some corrosion. Fluid is not leaking out but air is leaking in. If you take the slave apart and clean out the corrosion in the groove , may as well put in new seals, reassemble , and bleed the system, you should have the problem solved.
Sep 22, 2010 | Honda CBX 750 F Motorcycles
I have a Honda/Acura 1992 NSX. the Air Con cuts out when the coolant temp reaches 76 Degrees C. What could be the reasons? thanks
Quite possible, you don't have the correct amount of coolant in the system. Too much OR too little will throw the system off.
Aug 07, 2009 | 1992 Acura NSX
92 accord lx leaking on fuel rail
Dont replace just one O ring on the injectors. You need to replace all when you replace them. It sounds like you still have O ring leaks.
Jan 19, 2009 | 1992 Honda Accord
Air Conditioning and Heat for Acura NSX Logo
164 people viewed this question
Top Acura Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 TE5LA
TE5LA
Are you an Acura Vehicle Part and Accessory Expert? Answer questions, earn points and help others
