Question about Krups XP7230 Compact Super Automatic Espresso Machine
Service manual Krups ea8050
I will change the power button and need to get information on how to get inside the mashine the easiest way
    New Friend:
It's actually pretty straightforward - I called their service center up and they walked me through it. What you do is you snap the front open by its sides. I took the backside of a hammer and I just stuck it into the small gap on the sides of the machine where the front cover connects to the sides. You can try to "lift" the front up slightly. It's attached with just plastic hooks, so if you lift and bend, it will pop open.
Once you've done that, you see two screws, just unscrew those and then the backside of the panel is exposed. There, you can just lift up the button and replace it with a new one.
Posted on Apr 15, 2013
    New Friend:
Searching for this too to fix a rather simple problem - couldn't find it
Posted on Jan 14, 2013
2 Suggested Answers
  • 9 Answers
SOURCE: krups ea8050 give problem code 9 what's that
your temperature sensor is off. Good Luck
Joseph
Posted on Aug 31, 2012
KRUPS KJ502D51 Stainless Steel Triple Basket Deep Fryer ********** Just bought used . Has error 2 on display
Here is the manual in case you do not have it:. Scroll down until you find "Documentation" and then download the instructions.
http://www.krupsusa.com/KITCHEN-APPLIANCES/DEEP-FRYERS/4-5L-Deep-Fryer-with-3-Baskets-KJ502D51/p/8000035750
As far as the error code goes, Krups does not list anything. However, there is a reset button on this unit (see the manual), it may need deep cleaning, OR the internal battery needs to be replaced. If none of that works contact Krups (number inside the manual or on the website) customer support and see what they say.
Dec 07, 2017 | Krups Kitchen Appliances - Others
Krups EA8260 repair manual
That part is called a distrubutor and is not classed as a serviceable part so there is no information for it apart from a part number. I have looked inside one once and if you are careful and methodical pulling it apart you should have no problem putting it back together again.
Jan 03, 2016 | Krups Coffee Makers & Espresso Machines
How do i open krupp ea8010
manualspoint.com/results.php?search=krups+ea8010+service+service
Jan 17, 2015 | Washing Machines
I have krups xp7245. It just happened today after 2 yrs daily use.
These coffeemakers are not the easiest to work on, contact Krups and locate an authorised service agent in your area and run the fault by them, they will likely need to open it up to properly quote you. There are lots and lots of potential problems inside one of those machines. If you wish to look at yourself you are going to have to remove the top, sides and back covers. Side & back is one part. Even when you have it all exposed to not expect the fault to be immediately obvious, I have covers with cutouts so I can run it and look inside at the same time.
Feb 07, 2012 | Krups Small Appliances Espresso Machine
Hi, Can you please give me some indications regarding how to replace the boiler gasket on a Krups expresso machine E8050. I have removed all the covers/housing of the machine and I have 360 degree...
E8050 does not exist in the Krups info I have, EA8050 does though. You need to remove the tamping piston and unhook all the wires from off the PCB on the side. Then the boiler assembly is attached to the base with 3 screws. This will allow you to tip the boiler over enough to get access to the screw up through the bottom that holds that plastic flange thing on the bottom of the ejection rod while you at the same time have another screwdriver in the screw from the top into the only screw that you see inside the boiler. One of the screws will come undone, it doesn't matter which one. That will allow you to remove the shaft that the seal you are trying to replace fits around. It is called a Barista seal part number MS5015004
Dec 01, 2017 | Krups Small Appliances Espresso Machine
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
GVX2 krups coffee grinder; how to open it?
I have the same issue. You need to take both dials off, then on the bottom, there are 4 tabs on the inside. Seperate the halves and you will see them. Towards the front and halfway back. Pry the halves apart enough to push the top towards the bottom and it slides apart pretty easy. The tricky part now is finding the replacement part. I have super glued my switch and I want to do something to try and repair it further. Maybe epoxy. I called Krups and they can't sell the part to me. I called one of their service centers and they can't sell the part to me. So, if someone knows where to get the part, I am all ears :)
Nov 25, 2008 | Krups Burr Coffee Grinder
Brandt error D17
change sensor of drum costs about 20euro
Aug 19, 2008 | Washing Machines
Krups XP7230 Compact Super Automatic Espresso Machine Logo
1,943 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
