Question about Kodak Photo Printer 6850 Thermal
Incorrect ribbon message appears on printer screen
As i power it on, the message 'ready loading appears and the error light goes on. as i press the advance coz the message stays for long without the printer being ready. when i press the advance paper button checking ribbon message followed by incorrect message appears. what do i do?
4 Suggested Answers
SOURCE: printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Posted on Jan 16, 2010
SOURCE: My kodak All-in-one printer ESP9 goes instantly in
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Posted on Jan 14, 2011
  • 794 Answers
SOURCE: i have the same problem
Hi davecortazzo,
If you got 'Incorrect Ribbon ' error message in Kodak 6800 printer do the following thing :
1. First open the printer cover and clean the barcode sensor. The barcode sensor is right side of the thermal head.
2. If still same error message then you have to upgrade the firmware of your printer. You may download it directly from Kodak's website. Just kindly follow the instructions provided on the website. This should solve your issue.
Hope this helps.
Thank you for using FixYa.
Posted on May 30, 2011
My 5550laserjet hp printer showing 59.90 error
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Check this page out as well (parts) Error Codes and Support
Dec 21, 2017 | HP Office Equipment & Supplies
DIMM Error HP P3005n
Are you usingoriginal HP Dimm chip?, does machine turn on and come to ready when it is standing on it own (not hooked to p.c.) if not can you tell me exact light patten displayed
Dec 13, 2007 | HP LaserJet P3005n Printer
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
Action
Sep 06, 2016 | Laser Office Equipment & Supplies
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
Bc sensor error
Bar code read error: The printer does not detect the presence of the ribbon bar code sensor
1. Power down the printer. Remove the ribbon and wipe the two lenses of the ribbon bar code sensor with a lint-free cloth or cotton swab.
2. Install the ribbon and power on the printer. If the message appears again, replace the ribbon.
3. Power on the printer. If the message appears again, power down the printer and remove the paper path or top cover to gain access to the card cage. Make sure the cable from the ribbon bar code sensor to connector J122 on the controller board is undamaged and has a good connection to J122.
4. Power on the printer. If the message appears again, power down the printer and replace the ribbon bar code sensor.
5. Power on the printer. If the message appears again, power down the printer and replace the controller board. Record the message and return it with the defective board.
I have the parts in stock if needed cardenas_rory@hotmail.com
May 06, 2014 | Printronix P7005 Matrix Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
Code ereur 59
A code error 59:
Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
  1. Press the green c00099346.jpg (Select) button to continue.
    3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
    4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
Mar 02, 2011 | HP LaserJet 5550DN Printer
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
Action
1. Press the green <Tick Symbol>(Select) button to continue.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
Sep 22, 2009 | HP LaserJet 5500 Printer
Error 0xc18a0301 - "Ink system has failed" on a Photosmart 6180
Error number 0xc18a0301 on HP printers Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 28, 2009 | HP Photosmart D7160 InkJet Printer
Open Questions:
See all Kodak Photo Printer 6850 Thermal Questions
Kodak Photo Printer 6850 Thermal Logo
46 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
