Question about Dell XPS 420 PC Desktop
Mic not working since Windows 8 upgrade
Sound controller shows 'No audio devices are installed' on Recording tab
  • Badger467 Jan 12, 2013
    The upgrade was from Vista and everything else updated without any problems. The hardware that's causing the problem is the built in Mic socket and the Line-In, I've tried updating drivers from Dell and Realtek for the HDA but nithing works. I found a work-around using USB connectors but I'd still like to have the quick access to the mic and line-in
  • Dell Master
  • 1,824 Answers
When you were on Windows 7/Vista and you clicked on the installer, then it checked the devices, did it say that the device is not gonna work? Did you check the report for programs that may not work?
Try going to the manufucator's website and downloading the latest drivers.If you have upgraded to Windows 8 from Xp, then many things might not work as expected.
Hope that this answers your question.
Do you want any improvements on my answer? Please rate my answer by replying and saying that this helped and from 1-5.
Posted on Jan 12, 2013
4 Suggested Answers
latinmcgyver
  • 208 Answers
SOURCE: No Audio Device
hmm strange.. sounds like plug n play service issue or a bad xp install. with dells usualy u have to install 1st desktop system software then chipset then audio, video, ethernet.
Posted on Oct 05, 2008
justinbill
  • 14 Answers
SOURCE: i need an audio device for my dell desktop optiplex gx520 install
you can go to dells website and click support drivers and downloads type in the service tag of the machine (its 7 letters and nubers found on CPU Ex: BF14FJ1) and based on the service tag the correct audio drivers should be displayed for you to download.
Posted on Feb 24, 2010
  • 385 Answers
SOURCE: Even i installed the multimedia
Did you install Dell drivers? Here is a link for your drivers:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_GX620&os=WW1&osl=en&catid=&impid=
Install the Intel Chipset driver first.
Hope this helps.
Posted on Sep 15, 2010
My mic does not work on my microsoft lx-1000 head set, the audio works through the earpiece but no the mic, i've gone to set up a mic in the windows 7 settings but it does not hear me. I had a...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps W7
Jul 30, 2011 | Computers & Internet
My microphone is not working. What do I do? Trying to use Skype, but microphone want work
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
  1. Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
  2. Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
  3. Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
    If it's disabled then you need to install your audio driver's again.
  4. Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
  5. Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
  6. To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.sajjad4help_2.gif
  7. After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.sajjad4help_6.gif
  8. After you select ok , then you need to select microphone from the recording options to activate recording via your microphone.sajjad4help_7.gif
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
May 13, 2011 | Toshiba (P000257700) Microphone
Cant get the mic to work
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Dec 21, 2010 | Gear Head WC330I Webcam
Is there a microphone on this product? If there is, mine isn't working. How can i get it to pick up on audio?
Check out the audio settings on your computer to see if it can detect a mic
XP
Plug in your webcam
VISTA
Plug in your webcam
TEST SPEAKERS
Restart computer
Aug 30, 2010 | Radio Shack VGA PC Camera Webcam
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
VISTA
TEST SPEAKERS
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
My webcam works fine on other websites but when i try to talk nothing happens. It works fine when i test it but not on websites
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window'
VISTA
TEST SPEAKERS
Restart computer
Aug 25, 2010 | Logitech QuickCam Fusion Webcam
Hi I hooked up my HP web cam but the other party can only see me and not hear me. Any Sugestions ?
You need to make the mic you want to chat with 'Default'
XP
Plug in your webcam if it has mic
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your webcam mic the default device in the 'Sound recording window'
Configure the webcam to your chat program
VISTA
Plug in the webcam
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
CONFIGURE TO MESSENGER
Aug 22, 2010 | HP Webcam
People cannot hear me
If your webcam has a built in mic make it the default mic
XP
Plug in your webcam
Vista
Plug in the webcam
TEST SPEAKERS
Restart computer
Configure your webcam to the chat program
Aug 22, 2010 | Logitech Webcam
How to install the mic on this
Depends on your OS
If you have XP do it from the Control Panel (Classic View)
Plug in your webcam
Vista
Plug in the webcam
TEST SPEAKERS
Restart computer
Aug 21, 2010 | Logitech QuickCam Communicate Deluxe...
Dell dimension4600. microphone does not work. I have a portable microphone connect to the pink mic connection.
it might be a bad mic or it may be your mic settings
its worth looking into, try connecting a audio source to it when you are configuring it and have the volume control for the microphone (on the playback section) so that you can hear it when it starts working
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
Dell XPS 420  PC Desktop Logo
186 people viewed this question
Alun Cox
