If the battery charger on your Evatac flashlight blinks from red to green repeatedly when you connect the batteries to the charger, it could indicate a problem with the batteries or the charger itself.
Here are a few possible reasons why the charger is blinking from red to green:
The batteries may be faulty or damaged. In this case, the charger may not be able to charge the batteries properly, causing it to blink from red to green.
The charger may be detecting a problem with the batteries, such as overcharging or overheating. In this case, the charger may be designed to stop charging and start blinking from red to green as a warning.
There could be an issue with the charger itself, such as a loose connection or a faulty circuit. In this case, the charger may not be able to properly charge the batteries, causing it to blink from red to green repeatedly.
It is recommended to check the batteries and charger for any visible signs of damage or wear, such as corroded or dirty connections. If the issue persists, it may be best to contact the manufacturer or a qualified technician for further assistance.
if the charger is a 12-14 v charger you would have to charge 1 of the batteries at the time. connecting both in parallel during charging would cause a short. and in series (the way you have them wired) would provide too low a voltage for the batteries (6-7v each)
if the charger is 24-28v charger you would connect to the wires going from the batteries to the controls/motors (not the connection between the batteries) this will provide each of the batteries 12-14v charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
this happens if there is lose connections from the electric charger point, try connecting to other switch board, or there may be a problem with ur charger also, plz get it checked.
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
