Question about SewShop.com Brother Sewing Manual OVERLOCK PDF
Thread take-up cover came loose
Somehow the thread over came loose with a metal spring behind it, i'm not sure how to reassemble it again. Can anyone help me please
  • SewShop.com Master
  • 18,408 Answers
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
My wand reset button assembly came apart. When I reassembled the button is now loose. There appears to be something missing. There is no resistance ,spring like when pushing yellow release button.
Hi Alison,
I'm sorry to hear you're having difficulties with your DC07. You can purchase replacement parts directly from Dyson by visiting www.dyson.com and clicking on 'Parts'.
If you'd prefer to order over the phone, or would like to speak to someone in person before making a purchase, please call our free Helpline on 1-866-693-9766.
Kind regards,
Jack
Dyson Online Customer Support
Dec 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
How to change brush belt
OK, here goes... NOTE - any use of the words LEFT and RIGHT assume that you are looking from the REAR of the machine. NOTE ALSO - the machine has two toothed belts, it makes sense to change both while you're at it. Incidentally, this is a job you shouldn't have to do very often - Sebo belts usually last at least 10 years.
STEP 1. Separate the base from the bag compartment: press the button at bottom front centre of bag compartment and lift bag compartment upwards away from base. Sometimes this is quite stiff and four hands would be useful, you can lever it from behind with something relatively soft (the plastic handle of a dishwash brush works well) but take care to lift vertically upwards, not sideways or you risk bending a metal lever that's hard to get back into shape again. Rest assured that once you've pressed that button there is nothing holding the two parts together other than friction!
STEP 2. Turn the base upside-down and undo the FOUR DEEPLY-RECESSED SCREWS. All the surface-mounted screws are irrelevant to this job.
STEP 3. Turn the complete base right-way up, release the foot pedal and move the vacuum tubes out of vertical. The top cover will then lift off. You will see there are two belts - the pulley device between the motor and the brush roller is the sensor that measures the drag on the brushes and operates the automatic height adjuster to maintain constant drag. To the right of that double pulley is the electronic circuit board - note that it has a sensor that locates within the pulley device, be careful not to damage it.
STEP 4. At the left end of the motor cover, the drive cog is concealed by a small cover. Lift this cover out vertically, noting how it locates in the frame for when you come to put it back. Next, although not essential, it helps to remove the metal lever because if it falls out when you're not looking you may later be uncertain about how to locate the small coil spring. So slide that lever out towards the motor, noting how the spring locates.
STEP 5. Undo the two screws holding the circuit board (take care the washers don't slip away). Then undo the four screws holding the double pulley. Once that's free, you'll be able to change the belts.
Re-assembly is simply the reverse of the above process.
Jun 26, 2011 | Sebo X4 Bagged Upright Vacuum
My Singer portable (#6202/62120) keeps stitching nicely on top, but the bottom stitching is all knotted up! It's driving me crazy! I have tried everything. Any help would be greatly appreciated....
The bottom side is effected by the TOP tension. First make sure the top is threaded correctly. Best thing to do is completely unthread it and then thread it again. Then check the tension and make sure it is not too loose. Check the needle to make sure it is inserted correctly and not bent.
Once you've done that then you can take a look at the bobbin tension and make sure it isn't too loose too. Make sure the bobbin is in the case correctly, wound correctly and that the bobbin case is completely inserted right. You will hear and or feel a slight "click" when it goes in correctly,
May 24, 2011 | Singer Vacuums
THE ROLLER ON MY SHARK NAVIGATOR WILL NOT STAY ON, I CLEANED ALL THE HAIR FROM THE ROLLER AND IT STILL WONT STAY ON. IS THERE A BELT I NEED TO CHECK
We have only had our Navigator for 6 months and the bar won't turn. We took the whole beater bar head apart and it was a wiring problem in the beater bar motor.
What a piece of junk this is, very poorly made and has many design flaws.
Looking for something now to take it's place!
May 09, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
I have needles snapping and bobbin tangle
Try to repair in this order.
1) Your machine likely needs oil. Especially put a few drops of oil on the outside edge of your bobbin holder.
2) Try replacing your needle if you have some spares. If you are using a decorative thread (metalized) use a needle with a teflon lining on the eye (called metallic thread needle).
3) Try buying a better quality thread. Do not use generic thread in a sewing machine (i.e. "made in cheap country" with no brand name)
Please rate me..
May 04, 2011 | Vacuums
Stiches are loose in the bottom side of the cloth,if i change the bobbin case....will it help? I can understand that tension of thread is the problem.....but don't know what to do
the case the bobbin goes into has a little spring on its side .. the spring has one or two screws. one screw adjusts tension on the spring .. the bobbin thread goes under that spring when it is properly threaded .. if the screw is loose or missing then replace the screw or tighten it a little so that thread pulled thru the bobbin case spring has a bit of drag .. if its too loose then you can tighten the screw a bit more ... if you tighten it too much then it will pull the top thread thru to the bottom .. if your adjustment screw or spring is missing then you can replace the bobbin holder .. the new one should have the spring in place and be properly tightened .. . often the adjustment screw is just loose or the thread is not positioned correctly in the bobbin case slot. .
Jun 21, 2010 | Vacuums
My upright sebox4 will not stand . It keeps on dropping down.
This is usually a matter of lubrication (or lack thereof). If you look under the base of the machine, you will see that the "clip" as you call it is part of the metal axle on which the wheels are mounted. This axle is held in place by 3 metal tabs, each held by a single screw. About mid-way along, there's a spring coiled around the axle. That spring is what holds the "clip" (the bent part of the axle) against the tube that connects to the base of the bag compartment and holds it upright.
It's possible that your spring is broken, but often the problem is that the axle is sticking and the spring can't do its job properly. Try a small drop of oil under each of the 3 metal tabs. If that doesn't work, remove the 3 tabs completely, remove the axle (noting how the spring locates, so you can put it back correctly) and give everything a good clean. Then reassemble and try again.
May 14, 2009 | Sebo X4 Bagged Upright Vacuum
SewShop.com Brother Sewing Manual OVERLOCK PDF Logo
Top SewShop.com Vacuums Experts
Ron Lake
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
