Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony Rear Projection TV Screen is Green
The screen on my Sony KP53HS30 TV has turned green how do I fix it?
  • Anonymous Feb 12, 2009
    Our Sony XBR rear projection TV intermittently starts fading and then a very bright green flash which is almost blinding happens and then the screen goes black. If we turn it off for a few minutes, it will work again for a while. There are times it will work for 2 weeks and then start flashing green again.
  • 1694 Answers
SOURCE: hitachi rear projection tv. screen looks green
Green CRT bad = take off lower front cover, remove access panel
locate screen / focus block.....turn green screen control slightly
CCW............................re-assemble...........T.
Posted on Dec 21, 2007
C-Dog
  • 84 Answers
SOURCE: SONY KP53HS30 rear projection TV screen suddenly turned blue....
The blinking 5 times is an error code meaning that the white balance has a failure. And because you are experiencing a blueish screen then your problem lies in the circuit of the blue picture tube or possibly the blue tube itself is starting to go bad.
C-Dog
Posted on Feb 10, 2008
  • 185 Answers
SOURCE: sony 65 inch rear projection
behind the front grille there is a wooden panel remove it and yo will see a small black epoxy box with 6 knobs sticking out from it.
with the color turned down all the way, look closely for r,g,b on the box beside each knob this denotes which knob is for which color.
you need to adjust the 1 marked g on the bottom row. this adjusts the green bias to the green tube. this will get rid off the whiteish lines. adjust this knob counterclockwise in a darkened room untill the color shows a black and white picture. adjust slowly as the set will be monitoring what you are doing and will adjust itself as you adjust. bring the green down just enough so you don't see anything, make sure that you don't see red or blue either, if you do also adjust untill you don't see any color. these adjustments should be done with the input set to a video input that has no signal coming in the set will show the input label and nothing else.
when you have the raster( screen ) all dark you can go to an input with a signal and make sure the image is black and white adjust the bias of the color that is too much so that it is black and white.
hope this makes sense to you. now turn the user color control back to where you want it.you are done. reassemble, enjoy
you might have to do this again in a few months as the control you have adjusted are dirty and can't be cleaned with a cleaner.
moving these controls cleans them but the color balance procedure would have to be completed after such movement of these contols and any quick movement would have to be done with the set turned off. a quick back and forth movement will do a better job cleaning the tracks inside that adjustmet block but will mean you will need to do the setup adjustment all over again in order to get the screen blank and the color to balance to black and white. the top 3 knobs are for focus of the individual colos only adjust if the red, green or blue isn't sharp, you can try these to see with out doing harm. finally if thebias is too low then th lifgt on the front of the set might blink at you and the auto alignment might get part way through and stop. if this happens you need to bring the bias adjustment back up slightly. adjust only the bias for the tube that has too much color to start with and if this happens you will know that the bias control you just adjusted is the 1 that needs to be adjusted slightly.
Posted on Jan 04, 2009
albertv29
  • 87 Answers
SOURCE: Green and purple spots on my screen.
This unit requires the EEPROM correction tool Part # LSUQ0100.Only an authorized Panasonic service center will have this tool.
Posted on Jan 14, 2009
roety
  • 585 Answers
SOURCE: Sony 50' LCD Projection KDS50A2000 has a green tint on the screen
Yes sounds like a bad light engine (Optic Block), expensive part, but sony has extended some warranties on these for two or three years
link hope this helps
Eric
Posted on Aug 26, 2009
My sony kp-51ws500 tv screen would turn green and stay on for about 30 sec, then trun off. I adjusted the green screen button on the black box in the front of the tv....via info from this site. It fix the...
Doing the adjustment is not actually a fix, all that does is change the drive amount of the green CRT which allows the set to work but the 3 CRts will be out of balance so picture color will be affected. The only way to repair a bad CRT is to replace the CRT itself. You can get replacement Green CRT from www.tvrepairworld.com
Jul 30, 2011 | Sony KP-51WS500 51" Rear Projection...
Screen turns green and tv powers off.
visit your local service center. you cant do anything more up to this point
Jul 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony kp-57ws500 green screen then auto shutoff
I have the same tv and it did the same thing only now it has red hues all around the picture as well. The service guy told me it was the green tube and it would be about $500.00 to replace and may not fix the problem. What a p.o.s. I will not be guilty of buying any other Sony products from now on.
Jul 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Green screen...
Probable bad green CRT..........usually about 600.00....T.
Aug 04, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
168 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
