The picture has moved across the screen cutting some off. Usually in 16:9 but can see even less. It used to occasionally do it on Certain channels but would fix itself.. What's happened?
    Genius:
  • 1,669 Answers
It sounds like an output transformer problem in the circuitry. Get it fixed if you can.
Posted on Jan 12, 2013
  • 218 Answers
SOURCE: black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Posted on Nov 28, 2008
  • 304 Answers
SOURCE: 32 inch. samsung less than 2 yrs old. picture won't stay on.
The problem may be with the Main bd or the Power Supply. Have a trained samsung tech troubleshoot the set.
Posted on Jul 16, 2009
SOURCE: On Sony Bravia KDL-S40A12U screen occasionally
I have the same problem with any device connected to the HDMI, both sky and PS3 - I did find some comments that this was an issue with this set but I couldn't get anywhere with sony when I tried.
Posted on Jan 03, 2010
  • 1632 Answers
SOURCE: TV channel shows up behind the picture while watching dvds!
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Highdefjeff
  • 124 Answers
SOURCE: Describe your sylvania lc225ssx green screen
Whenever I hear "green screen" it is a loose or faulty HD cable(s).
Check your HD connections to make sure they are inserted fully and if there is no change, try an alternate cable.
Posted on Jun 17, 2010
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Replaced TY-LA1000 Lamp and now a black box across the picture, TV is PT-50LC14
Check in main menu (set and box if using one) under closed captions--one of the settings is TEXT--black box will appear in middle of screen and certain channels--with the remote turn text off.
Apr 05, 2012 | Panasonic Televison & Video
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Our tv screen is dark on certain channels and if the particular show is showing a night shot on every channel.
Try entering the "picture" sub-menu in your settings, then set the choice on "vivid" (or whatever the brightest setting is). If that doesn't work, try attaching the device on another input. Occasionally, if you are using the coaxial output of your device (the screw-on cable), it can give you a dark picture. If you have another output on the device, try it instead.
Jan 11, 2011 | Televison & Video
PICTURE WONT FIT ALL CHANNELS
Look for the button labeled format , zoom, aspect or picture size and press it until picture is the size you want.
Mar 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Cutting off the picture
please try once more in the memu on tv
Oct 14, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
