Question about Refrigerators
I need to cut up a chest freezer, I was going to cut the gas pipe and put it into a hose and vent it out the window, then I was going to cut it up with an electric grinder, is this the correct way?!??
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 26 Answers
If this is a natural gas or propane operated freezer[which I doubt,its probably electric] simply turn off the gas valve leading to it ,then hack away
Posted on Jan 12, 2013
Need diagram of were the air intake hoses go and gas tank hose thank you
Air Cut Off Valve, Fuel and Vent Hose Connections for a ...
? 4:11
www.youtube.com/watch?v=Jb6gckj_saw
Sep 16, 2013 - Uploaded by smallengineshop
Air Cut Off Valve, Fuel and Vent Hose Connections for a 1985 Honda Shadow .... How to diagnose carburetor vacuum leaks on your motorcycle
Aug 04, 2015 | GAS Motorcycles
Slow fill gas tank
either fluid is in the vent hose or the fill hose is pinched off somewhere under the car.. mechanic/tech can use an air hose to check for blockage
Apr 11, 2014 | 2000 Hyundai Elantra
Condensation on outside of chest freezer.water on floor
if someone repaired it before they eliminated the hot pipes responsible of such issue, if not is it cooling well if not it needs gas there is a leak caused from the pipes
Feb 10, 2014 | Washing Machines
How do I put a 90 degree elbow on the outlet pipe for a DLG0452W. I want it to exit at the prepunched factory left side exit.
you can do it either by cutting down the pipe inside the dryer,stick an elbow on the inside and run your pipe off of the elbow or cut the pipe and attach flexable vent line to the pipe and run that out of the dryer,or if you want to keep the pipe in case you change the dryer around in the future,remove the pipe from the blower wheel housing,buy another piece of hard pipe,cut it down and install it where the other pipe was,stick an elbow on it and either run hard pipe or flex line,use either hose clamps or the silver high heat tape to connect pipe,don't use duct tape it drys out and falls apart.hope this helps,it's kind of basic,just cut the pipe there or use another piece of pipe,cut it so when you put the elbow on it it will line up with the hole in the side.
Oct 08, 2013 | LG DLG0452W Gas Dryer
Electrolux chest freezer alarm keeps going off every five hours
Indicates not at correct temp, or frosting formation detection sensor has been activated. Check for ice forming on chill panel, if so may be low on gas, or may have defrost issues.
Chest freezers are a bit hard due to cased cores are not accessable and once issues start it impossible to rectify.
Hope that was of some limited help, sorry.
Dont forget to vote, thanks and goodluck.
Mar 20, 2011 | Freezers
My chest freezer was moved from my mother house to mine. now it won't get cold. I plugged it in for two days and nothing. it just stayed hot. please can you help me with this problem?
dear sir/madam
i think after shift your freezer to your house during of transportation it has been leak from somewhere in copper pipe so, please contact to your maintenance personnel for find out leakage and after brazing it, and refill the gas, i hope after this your freezer will work properly.
hope answer the question
thank you so much
please vote!
Aug 25, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Black & Decker BF53 Chest Freezer wont freezer after moving to another state. It worked fine and now its just freezing to a frost is all. I'm scared my food is going to spoil. Bought it second hand and...
dear sir,
i think after long trasporatation your freezer has been leek from any pipe so please contect to your service technician for find out that leek and refill the refrigrant gas .after that your freezer will be able to good cool.
hope the question,s answer
thank you .
Jul 09, 2010 | Freezers
Hi, I have a 01 Blazer that the gas tank "pops" I have changed the gas cap with that not helping also the fuel gage goes back from full to empty what should I do?
hi this sounds like you might have a vent problem, on the tank there is a pipe/hose that lets the tank breath if this gets blocked it could cause suction in the tank itself , do you have problems sometimes when you put fuel into the tank, like the pump cuts off as if it were full? this is a good sign that the vent pipe/hose is clogged and needs to be removed and cleaned or replaced if the pipe is collapsed.....hope this helps
Mar 16, 2010 | 2001 Chevrolet Blazer
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Nov 19, 2008 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
