Question about Epson Stylus Photo 1280 InkJet Printer
Solid Red Light, Solid Green Light, won't respond!!!
I haven't used the printer in several months. After dusting it off and replacing the ink cartridges, I tried to run the maintenance program through the driver software (downloaded). I always get an error saying "cannot communicate with the printer." Also, there is a solid red light. The printer will not engage its normal charging process, so I'm stuck pressing the big yellow button and the button next to the red light over and over again, but to no avail!!!! (yes my printer is hooked up to my computer via USB) so it should be "communicating." Any help would be very appreciated!!!
  • 1 more comment
  • ljsherm Feb 26, 2008
    Solid red light, and solid green light. Suggests that my computer is not communicating with printer, but they are indeed connected. I unplugged, restarted, shut down, etc.
    Problem started after printing about 20 pages, with heavy coverage and I got notice that the ink cartridge was empty. Replaced one and tried using a utility, and this is when I got the message.
  • Anonymous Mar 07, 2008
    Its the same problem-- the only thing is that I use this printer every day and when I try to print, a sign will pop up and said to "remove all foreign objects from the printer"... I don't know what that means but I'm sure I haven't put any foreign objects in it
  • Anonymous Mar 30, 2014
    have plugged in dongle and dreamgear into playstation. pressed dg button. lights flash faster then flash slower but never gets to one solid light showing. have left for 30min and more. have reset and tried again. no luck.
    Master:
    Sergeant:
  • 482 Answers
Go to www.epson.com find your printer, go to drivers and support. Documents & Manuals.
Posted on Mar 23, 2008
Buy another printer
Posted on Jul 13, 2007
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Epson R800 The power light is solid green and the ink button is solid red. I cannot print anything because one or more of my cartridges are empty, but it won't allow me to use the Status Monitor to check...
Open your printer cover and press the ink button. The cartridge under the out of ink symbol is the empty one. The following URL has the details: http://files.support.epson.com/pdf/r800__/r800__00u1.pdf#page=80
If you press the ink button again and another cartridge lines up with the out of ink symbol, record that. Repeat until the cartridge moves to the replace cartridge position. Buy all the ink you need before you attempt to replace any of the cartridges.
I hope this helps.
Nov 15, 2009 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus 440, solid light on for black ink, have replaced and still won't print
This morning I was researching to purchase a new printer to replace the 10 year one. The last cartridges I had purchased were from Printpal and made in China. They looked the same, but I had to force the door closed on them. With the solid red light on and replacing the cartridge three times with new ones from this order, it was time to find an old used cartridge from another company that I intended to refill myself. I did, installed it and the solid red light disappeared. The old Epson Stylus 440 is still ticking! However, I had written off InkGrabber for unused cartridges going dry in 2 months and now Printpal is on my $%%# list for non-uniform replacement cartridges as well as not lasting long. I am back to refilling my own. I had followed the instructions for resetting the ink level indicator, but to no avail as those instructions are for a blinking light, not a solid light.
I appreciate your website, if for nothing else, to be able to vent. Thanks so much for your follow-up inquiry and I'm sure you'll hear from me again soon about my old Epson.
Shirley
Aug 17, 2008 | Epson Stylus Color 440 InkJet Printer
Stylus Photo R280
Ink carts being not recognized and you say its a brand new printer?
Heres what you may want to try.
1. Turn off the printer and disconnect the usb cable from the printer
2. Press and release the ink button once you see a solid green light and solid red ink light
3. Open up the printer cover and check out where is the ink cart holder positioned
4. It should stop in the middle part of the printer, you should see an arrow or a ink out marker (ink icon with a / with it( indicating which ink cart is out or not recognized or expended. (This is a usual process on all the epson stylus photo series I had)
5. Press and release the ink button again, it should stop to the next ink cart which you are having a problem and if it doesnt then your ready to reclamp the ink carts.
Just follow your manual usually theres an on screen instructions how to manually replace or reseat the ink cartridges. If the issue persist, you may want to contact epson, ask for a warranty procedure or what you can do next for this. (Either a bad set of ink cart or a bad print head) Good luck!
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R-260 Printer
Which Led light is Red ? Ink Button? Open the printer cover then press and release the ink button, printhead will move to the center in which there is an ink out indicator pointing to one of the ink, press and release the ink button several time to determine what other ink/color are out. replace inks and try printing after getting a solid green light on power button...
Mar 11, 2008 | Epson Stylus Photo R260 InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
552 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
