Question about Acer Aspire Computers & Internet
I want a dual core processor upgrade
This is my desktop System Identification Manufacturer: Acer Model Aspire X1200 Processors: AMD Athlon(tm) Processor LE-1640 , WMCP78M Operation system: Microsoft Windows Vista Home Basic Service Pack 1 Motherboard Details Manufacturer: Acer Motherboard Model WMCP78M Bios ACRSYS - 42302e31 Memory Details Total No. of Slots 2 (Currently One slot in use) Installed RAM 2097152 MB Maximum RAM 4096 MB Front Side Bus 200 MHZ Details of memory already installed on your computer Memory Size Memory Type Memory Speed Dimm Type Dimm Type Detail A0 2048 MB DIMM 3189 MHZ 21 Synchronous
  • Acer Master
  • 7,627 Answers
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireX1200/AspireX1200sp2.shtml The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at: http://www.filehippo.com/download_speccy/.
Posted on Jan 12, 2013
cropp
  • 377 Answers
SOURCE: No Audio
oke
go to
http://www.driverfiles.net/page,show,317,,thinkpad%20600e%202645,search.html
oke
Posted on Mar 28, 2008
Joed911
  • 4338 Answers
SOURCE: The HP Presario A900 shuts down within 5 minutes of start up
If your laptop is overheating, it means that the Processor fan is not working. You can damage it further if you keep trying to us it. Although I must say, this is the first time I've heard of using frozen veggies to cool it down. I have a client that bought a portable Air conditioner to cool his laptop. I fixed it by replacing the fan.
The fact that the unit works while being cooled externally points directly to the fan.
Is the unit out of warranty?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
odiebugs
  • 949 Answers
SOURCE: notebook heating problem(urgent help)
You bios versions start at f.03,f.04,f.05, f.07, f.08,,,
The date and version that you posted does not match and bios version for your model.
The only reason you update a bios is if it falls under the problems
listed for the new bios to correct.
Say your lap came with f.05, the only reason you would update to f.07 is because you had a graphic error,that the new update fixed.
The link below is the page for your drivers, if you look at bios,it shows the newest,if you click on version,you will see all the ones
that where made.
You should double check to make sure that you have the right bios version.
http://h10025.www1.hp.com/ewfrf/wc/previousVersions?softwareitem=ob-61399-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3646603
Posted on Apr 14, 2009
  • 9 Answers
SOURCE: What to do?
Is it possible you have to enable some type of external display setting?
Posted on Aug 29, 2009
  • 1481 Answers
SOURCE: I have Acer Aspire-5570-4765 laptop
check the laptop specifiction from the Acer website....
Posted on Sep 26, 2010
Acer aspire x1200 - Will not turn on. no power at all
Had this computer to fix and it ended up needing a new CPU in order for it to come on! Tried everything before this and what clued me in was unplugging the 4-pin molex from the motherboard and seeing all the fans spin continually with just the bigger 24pin connector in there. That 4-pin connector powers the processor so that was it! Change out that processor.
Leaving my solution here for any others that may come by.
Feb 04, 2012 | Acer Aspire X1200 Desktop PC - Athlon X2...
I would like to upgrade my Acer Aspire 4315 PC Notebook it has celeron processor 1.73ghz 533mhz fsb 2.53gb ram running on win xp pro what dual core processor can this laptop take?
Well most modern laptops cannot not be upgraded in this manner because the processors are hard soldered on the motherboards. Even if you have a removable type processor the newer dual cores will not be compatible with your type of motherboard.
May 29, 2010 | Acer Aspire 4315 Notebook
Is it possible to upgrade the processor of an Acer Aspire 4732z notebook pc? its equipped with a dual core T4300 processor, and i want to know if its possible to upgrade to a core 2 Duo or a Core 2 Quad,...
Theoretically you could because both type of processors have the same socket.
Here is a link with more data about the socket:http://en.wikipedia.org/wiki/LGA_775
And here is a list with dual core processors: http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors
Good luck with your upgrade and keep us posted about this with a comment. Thank you for using FixYa
Apr 20, 2010 | Computers & Internet
Acer Aspire AX1200-B1792A AMD Athlon X2 4850e Dual Core Processor Microsoft® Windows® Vista Home Premium 64-bit, 4.0GB DDR2 320GB HDD. And i can't make any Windows Update since the problem...
Your operating system is corupted. you need to install a new one.
Your computer has the right specifications for vista though i would recommend Windows 7.
It is a much better Operating system
Dec 26, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
I recently purchased a new battery for my acer Aspire 3050 and was told that it wont work if my laptop was dual core.I'm not sure what that means, is my 3050 dual core
you are in luck the answer is no its not dual core
Acer Aspire™ 3050 (LX.AV10J.037) PC Notebook The Aspire single core™ 3050 from Acer® provides performance, flexibility and value in a compact system. Featuring an AMD Sempron™ processor, wired and wireless connectivity and a stunning 14.1” WXGA display, this notebook brings productivity and entertainment to a new level.Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Acer Aspire 3050-1733 Notebook
Want to upgrade my proccesor
OMG!! doogie812, quit giving people bad advice. From what you have suggested, you know nothing about computer hardware. You can upgrade the processor in this system and it will not effect the OS one bit, except make it process the data a little quicker. With this system, if you had done any research at all, it only comes with 1GB of memory, you should of suggested to this person to add more memory.
Jan 11, 2009 | Acer Aspire AM1640-U1401A Desktop PC
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Processor
I told you my opinion, If I was in your shoes I won't upgrade the CPU.Professionals do not do works against Factory specifications, and I fixcomputers for living.
Acer says Pentium dual is not supported on Acer 4315, I can only tell you not to do such an upgrade.
Itwould be the same as if you ask me if you can mount a Jaguar engine ona Mini, yes, for sure there is the way to mount it, but the car won'twork as it is supposed to, and risk to blow at first corner.
If you really want to replace your CPU consider the following.
Acersays pentium 2 dual core is not supported on 4315, if you do ityourself you risk to damage the computer. Do not do the CPU upgrade ifthis is your only laptop, or if you care of this laptop, chance ofdamaging laptop are high. This kind of upgrades are done more as anexperiment.
I know Core 2 Duo T5300 1.73 Ghz had been installedsuccessfully on Aspire 4315, Acer says not to install any core duo, Iknow for sure Pentium duo T5200 1.6 Ghz works on Aspire 4315 with noneed for replacing cooling system.
Both chipset are difficult to find, best place to find them is Ebay.
Check this link for an extensive report on this matter:
check also: Is it worth upgrading the CPU on Acer Laptops?
Aug 10, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
