Whirlpool WFW9250WROO starts a cycle and stops
All cycles start ok, fills w/ water, shuts off when full and beeps 3 times. Will not proceed. Drains ok manually. No control panel lights on right side. Unable to draw error codes.
  • Washing Mach... Master
  • 17,130 Answers
Possible that the fault still relates to a program controller malfunction.
check the door switch , check the connectors to the board.
Posted on Jan 12, 2013
  • CW Freeman Jan 12, 2013
    connections are ok. It appears the right computer panel is dead, the panel with the knob & timer light is ok
    Is it possible there is malfunction BEFORE the user interface/control panel at the Microcomputer,macine control PN W10299981
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    SOURCE: Whirlpool Model LSV6234AWO
    door switch bad?
    Posted on Oct 18, 2008
    • 86 Answers
    SOURCE: Control panel reads E61 at wash cycle and E66 and drain and spin
    Can you tell me what make this machine is? As it sounds like a heater problem??
    Posted on Dec 28, 2008
    LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
    THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
    Mar 01, 2015 | LG Washing Machines
    I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
    CM3 Operational Sequence.
    From Off, push and release the freeze button.
    1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
    2. Compressor starts when sump is full.Air cooled fan motor starts too.
    3. water pump stops early in freeze cycle for 30 seconds.
    4. Sump refills after pump starts.
    5. In low ambient condition,fan motor may begin to cycle on and off.
    6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
    7. Fan may shut off before the end of freeze.
    8. Harvest begins. Hot gas valve opens,pump stops.
    9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
    10. Harvest continues for preset first cycle harvest time.
    11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
    OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
    Oct 28, 2014 | Kitchen Appliances - Others
    Whirlpool deluxe WFW9150ww01
    Replace the analog level pressure switch, it sounds like it is bad, and the machine's overflow switch is the only thing stopping the fill from flooding your house... Whirlpool Washing Machine Pressure Switch WPW10239066
    Jun 04, 2013 | Washing Machines
    Cycle starts waters comes in, after about 30 seconds water goes out beeps 4 times goes off
    Hi
    It would be helpful to know the brand/ model etc.
    Usually if the water gets in, and then drains out straight away, the dishwasher thinks that it is either not filling, or over filling. If there are 2 pressure switches, there would be one for fill and one for overflow, the fill one (or the pressure tube to it) would be faulty.
    Otherwise, if there is only one pressure switch, it may be a dual switch, in which case it is faulty.
    If it is a whirlpool or LG, there may be an issue with the flow meter which checks the volume of water coming in.
    Best of luck with it. If there are further issues try to supply more info in your response as while dishwashers all do the same thing, some brands go about it in very different ways.
    Adam
    May 28, 2013 | Dishwashers
    Whirlpool WFW9050XW Washer Front Load
    Disconnect your mains from the wall and clean out your filter.
    Pl click if helped.
    Apr 28, 2013 | Whirlpool Washing Machines
    My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
    The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
    Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Machine will not spin or drain water.
    I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
    Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Washing Machines Logo
    Top Washing Machines Experts
