MY PROBLEM THE DOOR OF WASHING MACHINE IS CLOOSED ITS MODILE IS WF-J1061
After washing the clothes the door cloosed. how i can open itbecause it is full otomatic
  • Washing Mach... Master
  • 17,130 Answers
Please check this link to open the door; Click on Door lock
Posted on Jan 12, 2013
Master_Tech
  • 770 Answers
SOURCE: Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Posted on Jan 24, 2008
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
SOURCE: Dead LG WF-T8016TP washing machine
Solution # 2 worked for me. I used a 15A "fuses for microwave ovens".
item bar code 0 68938 90277 3. Cost $ 3.00
Thanks
Posted on Apr 26, 2009
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
Door will not open at end of wash.how can I open it? There are clothes inside.
Try unplugging the machine from the wall socket and wait 5 minutes and see if it resets itself.
Jul 15, 2016 | Hotpoint Washing Machines
A great deal of fluff is appearing on the washed clothes. The machine is an LG WF-T1391TP top loader, 15kg.
If you told us the make and model of the machine maybe someone could help?
Aug 12, 2015 | Washing Machines
I set washer to be on cold/cold but it comes hot??
CHECK YOUR HOSES- SEEMS LIKE THAY ARE ON THE WRONG TAPS
Jul 06, 2009 | Washing Machines
Will not agitate to wash clothes but will spin fine
call a repair man. you cant fix this yourself
Apr 26, 2009 | Washing Machines
Lg washing machine wf-t902. clothes tangling up
the machine has a broken wire to motor possibly
check that first
if not
does machine spin
otherwise at the bottom of gearbox under drive pulley there is a pring on main shaft and tah locks gearbox up
if this starts slipping on shaft it will only wash one way
remove and rough up shast refit and grease
Mar 16, 2008 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
