Will a 4wd transmission fit in 2wd 99 silverado 5.3
I believe it will, but you will have to ensure that they are both the same type, which should be a 4L60E if it's a half ton. You will also have to remove the transfer case and install the tail shaft extension onto the end of the transmission. Also, make sure that they have the same gear ratios. If swapping from a 1/2 ton to a 1/2 ton it should match. If swapping from a 1/2 ton or Tahoe to a 3/4 ton, there may be an issue.
The Grand Am unit will have an extra plug on the back for some kind of wires this is the problen!! Not the space in the dash
