Question about Samsung GT C5130 Mobile
Insert sim card is found in low signal
Call is hanging, insert sim card is found in low signal was out of root
    Master:
  • Samsung Master
  • 520 Answers
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Jan 12, 2013
3 Suggested Answers
  • 5 Answers
SOURCE: I can't insert other sim cards from this certain network
Sounds like the phone hasn't been unlocked properly. I had a similar problem and eventually just changed my sim to the original phones network. This solved all problems but i don't know wether this is the full solution to your issue. I tried to help best as though dude.
Cheers.
Posted on Jan 12, 2009
  • 64 Answers
SOURCE: whenever i get my sim
Your phone must be unlocked before you can use another SIM card. You can contact your carrier (most of the time) and get your unlock code, just supply them with your handset's IMEI number.
Posted on Jan 22, 2011
Phone ask me to insert simcard and hanging
It can't read your Sim Card. either your sim card or your cellphone
Jan 08, 2014 | Nokia E72 Smartphone
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
Jul 08, 2012 | Nokia E Series E7-00 Touch Smartphone-...
Hanging the phone n72 when insert sim card.
Your phone had a network ic i think it is the culprit here replace it with new one
Feb 18, 2012 | Nokia N72 Cellular Phone
Please help me. When i insert sim card in my sonyericsson s710a it will hange. Please tell me what to do
Hello,if when you insert the sim card the phone accepts it and shows the mobile network but still hangs then I suggest the sim card needs a replacement or you visit a repair engineer for sim slot servicing.
May 18, 2011 | Cell Phones
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Poor recepshion on my iphone
Reset the iPhone:
It has been observed that simply resetting the iPhone can resolve signal strength issues.
Reset network settings:
In some cases resetting the network settings has also helped so tap Settings, tap General, tap Reset, tap Reset Network Settings.
This will restart your iPhone and will also delete any stored Wi-Fi passwords as well as DNS settings and more.
Place your SIM card again:
If your iPhone’s SIM card is not placed properly, it has been observed that it can affect signal strength.
So a good idea would be to remove your iPhone's SIM card by pushing a straightened paper clip into the small hole on the top of the device to open the SIM tray, then check for debris inside the tray or SIM card slot, remove it by blowing into the slot or using compressed air and then placing the SIM card properly and then re-inserting the SIM tray.
The notion is that improper SIM contact can result in a weak signal, so the above procedure could help.
Attaching scotch tape to the SIM card:
This is indeed the most ingenious methods, it appears that attaching a small piece of scotch tape to the outer side of the iPhone’s SIM card (the side of the SIM card that does not have metal contacts) can result in a surprising boost again borrowing from the notion that improper SIM contact can result in a weak signal.
May 25, 2010 | Apple iPhone 3G
I can't turn off the SIM Lock
Hello, Please get the PUK code on your service provider,
Kind Regards, Jay
Oct 05, 2009 | Nokia 5310 Cellular Phone
Hi sigmatels4 insert sim card problem
if signal strength is to low s4 doesnt recongnise ur sim card airtel stoped gprs service to these china mobiles
Jan 26, 2009 | Handmark Software MobileLists (950142) for...
Samsung GT C5130 Mobile Logo
109 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
