The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
  • Washing Mach... Master
  • 17,130 Answers
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Posted on Jan 12, 2013
  • 1462 Answers
SOURCE: Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Posted on Sep 07, 2008
  • 135 Answers
SOURCE: Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Posted on Nov 11, 2008
  • 99 Answers
SOURCE: Door Won't Open
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
Posted on Feb 13, 2009
SOURCE: Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
Posted on May 04, 2009
  • 14 Answers
SOURCE: aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Posted on Sep 07, 2009
Lights flashing and unable to start cycle. Helped once when turned off at mains but not now.
Hi it could be your door lock switch your machine on and wait for 6 seconds and try to open the door if you can thats your problem or may be that the door catch ic worn try and push the door shut with a bit more force
Jun 29, 2011 | Hotpoint Aquarius WF210 Front Load Washer
How do I stop cycle and unlock door?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 27, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
Aquarius 1100 - door won't open
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Door Won't Open
This is joyce
thanks
joyce
Feb 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Tumble dryer hotpoint ctd00
Unscrew all screws that hold the 2 halves of the door together, then with a screwdriver or similar, prize apart the 2 halves of the door, be careful the door glass does not fall onto the floor.
Fit new parts, reassemble door, and hey presto!!!
Dec 16, 2008 | Hotpoint NWXR473EV Dryer
Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Dec 15, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
